We like to hide from our neighbors. They get all needy.Why aren't one of you nerds my neighbor?
This is such an important point. And it happens for any sort of offered assistance. After helping my neighbor with a plumbing job, I now seem to own his entire plumbing situation. I install a toilet, and in a few weeks, he wants to know why that made the kitchen faucet start leaking... Same with electrical. Once it is touched, it then becomes my problem. So I agree... helping folks modify their cars is something that I generally shy away from. I'm happy to show people how, not so happy with actually doing the work. And even showing how can come with similar strings attached, unfortunately...I'm ok with modifying my Model 3 but it always gets a bit more complicated if I updated a car that is not my own. I've had situations where I suddenly became the lifetime tech support after I applied my initial mod to a friend's computer. Any quirk or weird behavior I suddenly became the level 1 tech support line. After that I said "no more" I'll just mod my own devices.
Pretty sure 2835s are what I used. You should be fine. Cheaper than the set with the switch too if you aren’t going to use it elsewhere.
Honestly, even if you crack any of the plastic while prying, the project is not ruined. Super glue would put it back together just fine. Remember that all you see is the clear lens... everything else, not so much. It just takes a bit of patience. And once you've done a couple of them, you'll get the knack, and figure out the best tool and method.Whats the easiest way to pry the black housing from the clear holder?
I am scared by using a small screwdriver i am going to crack the plastic by prying the 4 holes at the side one at a time
I've found that 3 is ideal. Yes, you can make them brighter, but I don't think that the extra current draw, and extra heat is worth it. Three fits so perfectly, it's meant to be!Thanks! Ordered. Can’t wait for them to come in on Monday.
Did you only do 3 LEDs per light replacement or cram 6 into each unit? Trying to determine if it’ll be too bright with 6 6
Totally guilty as chargedThe LEDs for me was just scratching that itch to monkey around with a car and there is not a lot you can do to a Tesla.
That's awesome!You guys like making stuff with LEDs... look at this. I added a wireless remote relay that turned on momentarily and persistently. When the headlights are on, the lights look like eyes and the LED strip a smile.
Good idea about the solder prior to install.Thanks @KDGr the LED density is perfect! Just replaced all my light fixtures and now everything is 3x brighter! I selected the 600 LED cool white lights. It was impossible to unsolder the original single LED module so I followed the suggestion of breaking off the original module at the connecting side and it worked great and saved a ton of time. I ended up upgrading the lights to the entry door lights (4x), foot well area (driver and passenger) 2x, and finally the trunk 2x. All together had to retrofit 8 modules. This saved me a TON of money. Be sure to add some solder to the LED ribbon connector prior to installing into the light module. It makes is much easier to solder to the power terminal posts.
Update: added two more images, the LED reel box and the reel it self. Just have to cut along the cut symbol area. Very easy!
I'll give you a tip to make THAT easier as well: Use a proper flux. Suddenly all solder projects go better.G
