To be a perfect fit, how long would the SS lines need to be?I didn't take a photo, but my MPP SS Brake lines are too short to mount the tab to the knuckle. So, I just zip tied it into itself to reduce the slack from catching a rotating part.
Yeah my mpp lines were a bit tight also had to rotate it to fitI didn't take a photo, but my MPP SS Brake lines are too short to mount the tab to the knuckle. So, I just zip tied it into itself to reduce the slack from catching a rotating part.
That’s good to know, since ordering lines and pads is next on the list for me. My calipers are here, though! Just need a car to put them on…Yeah my mpp lines were a bit tight also had to rotate it to fit
Whatever the MPP are, add on like 2-3 inchesTo be a perfect fit, how long would the SS lines need to be?
Yeah, definitely didn't think of that.Typically, with a different caliper you will also need a different line. On the Camaro I did the CTS-V BBK upgrade the SS line had to be upgraded.
You can get some of the best lines custom made by Spiegler:Yeah, definitely didn't think of that.
Wow, that's some serious customization. Now just need someone to get some stock lines in their hand to spec them out... Thank you!You can get some of the best lines custom made by Spiegler:
Motorcycle Performance Parts | Custom Motorcycle Access
Spiegler Performance Parts was founded on the concept of providing motorcycle enthusiasts custom motorcycle accessories and performance parts via innospieglerusa.com
They use Spiegler lines.Working with Essex now to see if they can build us a proper brake line with a 90 degree banjo fitting on the caliper side.
I’ll report back shortly.
Just took a pic of my lines. Since I was swapping in the pagid rsl 29 padsTook photos this morning of the brake lines.
First is full stretch of the line with full lock on steering wheel. Second is full slack by turning the steering wheel full lock in other direction.
Without me tying the lines this way, I could get the guide tab mounted into the knuckle, but it's too taught and I wasn't comfortable with that strain on the lines.
So, another 2 to 3 inches would've been perfect.
These are MPP lines, and you are showing you aren’t having issues with stretch?Just took a pic of my lines. Since I was swapping in the pagid rsl 29 pads
View attachment 834492View attachment 834493
It’s pretty tight but had to angle them certain ways but no stretching issue is the boot doesn’t allow for much rotation.These are MPP lines, and you are showing you aren’t having issues with stretch?
I was worried the tension would increase fatigue on the banjos. Decided to play it safe and zip tie it.It’s pretty tight but had to angle them certain ways but no stretching issue is the boot doesn’t allow for much rotation.
What does yours look like at full lock/tension? When I had my tab mounted there was definite strain on the banjo no matter how I oriented it (flipped and all that).Just took a pic of my lines. Since I was swapping in the pagid rsl 29 pads
