In this post, I mentioned that there was no law to prevent someone doing DIY electrical installation work, and that it was perfectly legal, as long as the regulations were adhered to, that the work was undertaken by a competent person (which doesn't mean formally qualified or approved) and that if building control approval was required then the appropriate application and sign off be obtained: Charge Point / Charger Suggestions [megathread]
First off, I want to state clearly that DIY electrical installation work is potentially hazardous, may pose a risk to the person doing the work, their family and perhaps their neighbours, so it should only be considered if the person doing the work fully understands the requirements, has access to the required test equipment and is fully competent to do the work.
Rather than clog up that other thread, which is specifically about charge points, I thought I'd clarify what I said there, with some detail about the law, electrical regulations and building regulations. Firstly, when referring to electrical regulations I'm referring specifically to BS7671, the current edition of which is 2018, amendment 1. This is law, in as much as it is a Statutory Instrument, so the regulations within it should be complied with. However, failure to comply with BS7671 is not an offence itself. Like most SIs, BS7671 provides a guidance framework for the standards to which work should be undertaken.
I'm very well aware that there is a powerful "electrician's mafia" out there that will roundly condemn the very suggestion that DIY electrical installation work is safe. Some of the more extreme members of this group may well try and wrongly make out that it's even illegal. Clearly there are important safety considerations, and there are enough examples of truly dodgy DIY work to give the "electrician's mafia" all the fuel they need to maintain their frenzy against DIY'ers, but I've seen several DIY installations that have been exemplary, and to a higher standard than many professionals.
There's also an assumption by some within the "electrician's mafia" that anyone undertaking electrical installation work must be qualified and hold the relevant certificates. This just isn't true, anyone can do work that's fully compliant with BS7671, so legal, without needing any bits of paper. Clearly, being formally trained and qualified may well be a requirement for someone in the business of undertaking electrical installation work, if only so they can obtain things like public liability insurance, but for a DIY'er there is no qualification requirement at all.
The only law that can be broken by a competent DIY'er doing electrical installation work, in England and Wales, is that relating to Building Regulations. Failure to comply with these can result in a very hefty fine or imprisonment. Some electrical installation work, like any new outdoor power outlet, including a charge point, has to be approved under Part P of the Building Regulations. Normally, this is a formality for any suitably registered electrician, as they can self-certify compliance with Part P and submit the required notice to Building Control. However, any homeowner can do much the same by just making a building regulations approval request to their local building control body. This isn't free, there is a fixed fee to pay, but there is a mandatory requirement that building control bodies offer this service.
