DIY Home EVSE
Discussion in 'Supercharging & Charging Infrastructure' started by vfx, Aug 24, 2011.
  1. vfx
    vfx Well-Known Member
    CA CA
  2. W.Petefish
    W.Petefish Active Member
    It is good but, it advocates steps that might not be necessary.
    That makes me wonder how much you would save with making your own EVSE?
  3. TEG
    TEG Teslafanatic
    There seems to be a fair bit of room to cost reduce from what is available now. Getting down to under half the current prices seems doable.
    Some references:
    My Nissan Leaf Forum View topic - Weekend(s) Project - DIY EVSE
    Home Brew Charging Stations ()
    A fair bit of the cost is still the plug end. It will be nice when you can find good quality J1772 plugs for well under $100...
  4. doug
    doug Administrator / Head Moderator
    SF Bay Area
    ...in a bin at Home Depot or AutoZone.
  5. vfx
    CA CA
    A Leaf friend bought his EVSE at Lowes.
  6. W.Petefish
    I find that hard to believe.
  7. vfx
    CA CA
    From his email.
    We are in the LA/Ventura CA area.
  8. TEG
    TEG Teslafanatic
    EVSE to be Available at Lowes
    I think you could build your own for under $500... (But what is all the labor worth?, and you won't have a well tested, certified product...)
  9. vfx
    CA CA
    Same reason I bought the Roadster over a conversion that I liked the looks of better.
  10. TEG
    TEG Teslafanatic
    Twitter
  11. W.Petefish
    I stand corrected.
  12. W.Petefish
    It would be worth it to be able to have control over the size of the EVSE.
  13. TEG
    TEG Teslafanatic
    Yes, and there is a lot of learning value in building your own things if you are so inclined and capable.
  14. W.Petefish
    I think that in my spare time I will try to make one. An instructable will be made for anyone else who wants to attempt to make one.
  15. dwegmull
    dwegmull 2013 Model S 85
    Redwood City, California
    I am (slowly) working on my own charger, mainly as a way to learn about it.
    My goal is a portable charger that can be used when going to a friend's house either for a few hours (i.e. to share a meal) or overnight. To keep light and compact, I decided to design it for a 30Amp circuit (24A continuous). In a typical house, the laundry area is near or in the garage, so I picked a cloth dryer as my plug of choice.
    This is a very basic but safe unit: it has a GFCI, and it implements the full diode check protocol.
    Parts wise, I ordered a 30A cable from a supplier in Arizona which name's escape me at the moment. I was about $300~$400. I'm using a 30A contactor, from Digikey. The GFCI is a "donut" model meant for a hot-tub (available from any hot-tub and spa supplier). I have a tiny power module that takes anything from 90VAC to 240VAC and outputs 24V. From there I create +/-12VDC and +5VDC to power my processor. The "brain" is an Arduino Mini-pro. I have most of the code written which takes only a few KBytes. There is a relay under control of the Arduino that can control the main contactor, in series with the GFCI: as a result, for power to be present, both the GFCI and the J1772 protocol must be happy.
    The whole thing fits in a outdoor grade box (meant to be used for industrial control boxes), sourced from McMaster-Carr. I think it is 7" x7" x5". There is no user interface other than the GFCI reset and test buttons. I figure most cars have plenty of indicators built-in to let the user know what is happening. A possible extension would be a Bluetooth serial port module that would allow me to use my mobile phone as an interface... I figure I'd get the basics right first and the bells and whistles later!
    I will post some updates and pictures here soon.
  16. TEG
    TEG Teslafanatic
    Cool! I know you are definitely a 'maker' of all sorts of things.
    Sorry to correct you, but as you probably know, the "charger" is in the car. So people tend to refer to these things as the EVSE or charging equipment.
    Probably these guys:
    J1772 Adapter
  17. DaveD
    DaveD EVs Kick Gas!
    Redmond, WA
    even better would be in the surplus bin, because the Mennekes connector supplants it. Hope springs eternal.
  18. dwegmull
    Yes, I got the cable from Tucson EV. I just noticed a significant drop in prices: the 70A model (plug + cable) is now down to $250. This is a lot less than I paid for my 30A cable a few months back! I hope this will lead to more DIY projects.
  19. TEG
    TEG Teslafanatic
  20. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Wimpy 30 amp charger! It would take about 18 hours to charge an empty Model S battery! Fine for a leaf however.
