Fuzzylogic
Roadster Sport 2.5 & S100D
The LM358 is used for GFCI not the pilot, it is far too slow for the 1khz square wave. The pilot uses the LF353 which is a much faster opamp, it is not a rail to rail device so it does have a small voltage offset (spec sheet says 10mv). I only have access to a LEAF, so far the pilot with the LF353 works perfectly. If other vehicles have an issue with the slight voltage drop, an LT1498 would be simple to drop in...
I am not sure why it will not solve GFCI (typo maybe). GFCI is performing quite well with the EVSEs I built so far.
Oh i'm sure your GFCI design works, looks very good actually... I just meant that changing the Opamp to a rail-to-rail device might prevent connection problems on other cars.
I just double checked your schematic, but IC2 is labelled as a LM358 (typo) ?
