DIY Home EVSE
Discussion in 'Supercharging & Charging Infrastructure' started by vfx, Aug 24, 2011.
  1. widodh
    widodh Model S 85 and 100D
    Venlo, NL
    Ah, you are right!
    I prefer Github btw, much easier to use GIT with branching :) I'll probably send you a couple of patches to make 3-phase easier.
  2. hcsharp
    hcsharp Active Member
    Vermont
    That's because it IS homemade.
    Only rated for 25A??? It looks like a lot of phantom load when charging and not charging. I'll bet that thing consumes 15 or 20 watts when it's charging (on top of what's going to the car).
  3. widodh
    Venlo, NL
    I finally got my 3-phase 40A relays and hooked it up to see if it worked.
    It works, but it seems the load is to high for the EVSE board. My multimeter is showing me that the relays is using about 450mA, while the board is designed for 300mA, correct?
    The big black thing labeled "MPD D107E" gets warm and starts to make a "sissing" noise.
    Next to the relays connection there is a 12V/GND connection on the board. What is the maximum load for that? If that can handle the 450mA better I'll probably buy a small relays in between to switch on the big relays.
  4. Chris1howell
    Chris1howell Member
    Los Angeles, California, United States
    450ma @ 12V (5.4W) is far too much. The OpenEVSE Power supply is only 4W. The OpenEVSE board and Adafruit LCD use less than 1.5w leaving more than 2.5w for the relay... The D107E is he DC/DC converter for the pilot. It is probibly getting hot due to a voltage drop when the relay kicks in... Is your relay avaliable with a 230v coil? You can use a much smaller relay to switch 230V to your 3 phase relay and stay within the 4W.
  5. widodh
    Venlo, NL
    I can't return the relay anymore, it was a special order.
    The 230V version is also much more expensive.
    I think I'll take a doorbell transformer which outputs 12V 1A and use a small relay to use the doorbell transformer to turn on the big relay.
    12V doorbell transformer ----> Relay connected to EVSE ----> Big relay
  6. mitch672
    mitch672 Active Member
    Stoughton, MA
    Just an FYI, OpenEVSE released new firmware that allows setting the pilot amperage via a 1 button menu system, viewed on a 2X16 RGB LCD display, see the homepage for pictures: http://code.google.com/p/open-evse/
    Also in the news Leviton is now selling 30A J-1772 cable, 25' long for $126, this has brought down the price of building a 30A portable OpenEVSE to a little over $400, see my build link below, which has been updated with the new lower cost Leviton J-1772 cable: http://code.google.com/p/open-evse/wiki/EVSE_by_mwolrich
    Mitch
  7. widodh
    Venlo, NL
    Nice!
    I'm still working on my 3-phase version, but that should be up and running in about 4 weeks I think.
  8. dwegmull
    dwegmull 2013 Model S 85
    Redwood City, California
    My own EVSE is done! I started this effort before I was aware of the open EVSE project; however I decided to continue with my own design mostly for my own education. While the J1772 part itself was fairly strait forward, the GFCI, was another matter...
    I can confirm that off the shelf GFCI "donut" modules designed for hot tubs do not work with the Roadster! The unit I bought did provide a nice coil that I ended up using with my own circuit.
    I put all my design notes (including schematic and source code) in one document here: J1172 Design Notes - Google Docs
    Here is a picture of the finished unit:
  9. widodh
    Venlo, NL
    Nice! I'm not that familiar with the US connectors, but is this one 40A (Nema 14-50?)
  10. dwegmull
    It started life as a 14-50, but I removed the unused neutral prong, so it can be plugged into either a 14-50R (common at campgrounds) or a 14-30R which is used for clothes dryers.
    For those of you not familiar with US wiring, most houses are supplied with two 120V phases, 180 degrees out of phase with each other. Most small appliances are connected between the neutral (which is grounded at the main panel) and one of the two phases.
    Some large appliances (Such as the Roadster) run on 240V by being connected to the two phases.
    Finally, some appliances, such as clothes dryers use 120V (for the motor) and 240V (for the heating element). This why there are four prong plugs: two phases, one neutral and one protective ground.
  11. TEG
    TEG Teslafanatic
    I think it is preferred to call it one split phase, not two phases...
    Two-phase electric power - Wikipedia, the free encyclopedia
  12. wycolo
    wycolo Active Member
    WA & WY
    > single phase power & how to confuse the hell out of rubes:
    Especially wrt EVSEs, where the NEUTRAL is being UNused, the 240 volt legs go directly to the opposite sides of the SAME WINDING in the pole pig on your power pole. Read: ONE CONTINUOUS WINDING. Therefore by definition: UNITY, the SAME IDENTICAL PHASE ! ! [disappears over the horizon, pulling hair & sputtering]
  13. vfx
    vfx Well-Known Member
    CA CA
    UPS into a charger and more.
  14. TEG
    TEG Teslafanatic
    First commenter had some important safety observations about the device VFX just mentioned:
  15. widodh
    Venlo, NL
    I did some work on my EVSE yesterday. It took some time for my shed to be build, so I got delayed by that.
    I have a blogpost online about it: Widodh Installing the socket of my Open EVSE
    My question is: Does anybody have a suggestion about how to control the actuator with the Open EVSE board?
    To lock the connector I need to send 12V to the socket for 300ms and reverse the poles for unlocking the connector again. This is to prevent the connector from being pulled while charging.
  16. Kevin Sharpe
    Kevin Sharpe Active Member
    Bradford on Avon, UK
    I would suggest a Type 2 socket with a solenoid that opens when power is removed. Lots of drivers have experienced cables being locked into EVSE when power is removed using the solenoids you describe (rumour is that the latest Mennekes sockets even have a manual release mechanism to try and overcome this issue).
  17. widodh
    Venlo, NL
    The socket is already installed.
    The red lever you see is indeed for a manual release.
    The EVSE is only for my home, so I can easily open the socket if it jams for some reason.
    See my blogpost above for more picture of the socket itself.
  18. widodh
    Venlo, NL
    #180 widodh, Sep 25, 2012
    My other components arrived! The installation is working here, just waiting for the last couple of bits in my shed to be ready and I can install everything and it will be ready.
    I created a short video to show how the layout is:
    As you can see, a 40A 3-phase relays is quite big and won't fit into a Open EVSE box, so instead it's in the distribution panel which will go into my shed.
    Attached is a picture of the panel which gives a better look of the wiring.
    Once everything is installed I can hook up the Roadster (after some testing, more testing, more testing and even more testing!) and hopefully a 3-phase EV as well :)
