My plan is to DIY install a Tesla Wall Connector AND apply for the 50% Ontario rebate.
The rebate is worded such that an Ontario Electrical Safety Authority (ESA) inspection(s) seems to be required (of which I can get a 50% rebate on as well).
I plan on a 60 amp circuit breaker, 6 gauge wire and full conduit.
My circuit breaker panel is a 200 amp service located in my 3 bay garage, such that the panel's location is where the "passenger side rear fender" of my future Model 3 is.
Thus, I could mount the WC within 12 inches of the panel.....but I would always have to run the WC cord along the rear end of the car to connect into the drivers side rear fender location.
My other option is to run my circuit a total of 23 feet, from the panel along the side, top and other side of the garage door.
The only "issue" is that this location (which would be perfect for being close to the rear left fender of the car) is only 18 inches wide between the garage door rails (between the bay where my car will be parked and the next garage bay).
Ontario Electrical Code issues: do I need a separate 60 amp disconnect switch for this project, or is the circuit breaker itself considered adequate?
Is the 18 inch width between garage doors too narrow, thus forcing me to mount the WC right next to my circuit breaker panel?
Is 42 to 48 inches above the floor a correct (code wise) height for the WC?
Are there any other unique (for EV connectors) rules in the code?
Thanks
Thanks
