DIY: Model Y Painted Calipers
How are you jacking and holding the car? is that jackstand placed at the lift point or somewhere else? thanks
I'm so tempted to buy the quickjacks but wanted the bigger one to go on sale so i can use it on the cybertruck
As im lifting the rear, the front elevates off the ground. I seized the opportunity by sliding the jackstand in the front where the jack point is before lowering it down in place.
I did the same vice versa to lift the rears on to Jack stand.
Looks good, anyone match midnight blue metallic?
DIY was commonly done by Model 3 owners, but so far I haven't seen any posts about Model Y owners doing it. I watched a ton of YouTube videos and decided to take on the challenge. I'm not car savvy at all, but was intent on saving $500-$600 that I was being quoted for painted calipers.
I went to Harbor Freight and bought:
  • 3 Ton Low Profile Floor Jack ($100)
  • Jack Stands ($40)
  • Torque Wrench ($20)
  • Breaker Bar ($10)
  • 21mm Deep Socket ($4)
I bought on Amazon ($30 total):
  • VHT Caliper Paint
  • Rust Oleum High Heat Primer
  • Rust Oleum High Heat Clear Gloss
  • Jack Pads
And then I got to work.
After removing the wheels, I cleaned and sanded the calipers.
3UEYN8a
JVhdZvH
I then masked off all the areas.
NjOl761
I did 2 coats of Primer, 3 coats of Red, 2 coats of Clear (all coats 15-20 minutes after the previous). I added the emblem before the clear coat.
Hy7WgnB
Finished Product
dlOratL
ngL8Pke
Don't be intimidated by this Model Y Family. No need to pay someone if you want painted calipers! The paint materials is less than $50 and the jack and other tools can be used for tire rotations (save $50-$100 every year). I did 1 side per day. Each side took me about 4 hours, start to finish. But, there's a decent amount of down time between coats.
Thank you for the detailed instruction set. I mimicked mostly what you’ve done and I did it.
This is first time I used a Jack and Torque Wrench :) Rear calipers are such a pain though!
I had read something about painting the calipers voiding the warranty. Can anyone shed some light into that? Would it be voiding it just for the brakes or the whole car?
If your in the US, look up the magnuson-moss warranty act. Short hand, Tesla would have to prove (in court) that a few layers of paint were the cause of whatever item you were attempting a warranty claim on. So, to answer your question about voiding the entire cars warranty, no; the braking system, again, they would have to prove that painted calipers were the cause of whatever braking component Or components failed. People have been painting calipers for decades, this isn’t something new.
Reactions: Traveler85
Weekend project... Think yellow calipers goes well with blue metallic and induction wheels. Just did the front so far. Would it look awkward to not do the rear calipers?
Looks awesome! You have a whole picture? Would love to front and rear calipers in a single picture to how it looks overall. I have a blue MY coming so deciding on caliper colors.
  • Jack Stands ($40)
  • Breaker Bar ($10)
  • VHT Caliper Paint
  • Jack Pads
Awesome work. This is what I planned to do when I get mine Blue MY. Will paint it blue. Only drawback is the limit of jack points. It seems no matter what, you can only do one side (2 wheels) at a time since there is a maximum of 4 jack points on the MY.
Any way to get all 4 wheels at the same time using regular floor jack and jack stands?
I think if you have enough jacks you can do it. A lot of pros that paint calipers are mobile. They come to your house and do all 4 at the same time. They bring multiple jacks.
