I mounted the kit from Cozero this weekend, I can confirm that cutting the wire works.Has anyone tested whether cutting this wire works !
Wow, your trunk looks like it opens a lot bigger than mine.Forgot all about YouTube:
Your trunk shuts really gently and smoothForgot all about YouTube:
Mine on the other hand slams shut pretty hard
I thought about trying to find someone in the Los Angeles to do mine, as I'm pretty low on free time for DIY projects right now (but I want this upgrade after having a loaner with the power liftgate, it's a shame Tesla won't let us pay them to do a retrofit now that it's standard across the S/X).I need to find someone in Denver to do this as after my loaner car which has it, it is hard to going back to my hands but while I’ve always been a do it your self kind of guy on all of my previous cars I tend to stay away from the Tesla and I’m running out of recreational time.
It is the version 2 with soft lock, you replace the latch with one that has a motor to pull it.Your trunk shuts really gently and smooth
Mine on the other hand slams shut pretty hard and I haven`t been able to find a solution for that
Did it work like this out of the box or have you tweaked it to operate like this?
Did you ever manage to get the button to light up? Just mounted the OEM button, no light.I thought that too till I looked at another car, the factory button definitely lights up.
Ok, was thinking if the power could be taken from the trunk light, if it is 12 volt. The light is kind of handy during the dark vintner months here in Denmark.Nope, wondering if it just doesn't have the correct voltage or something? The button that comes with the kit lights up. If the OEM button is operating the trunk I'd image the wiring is correct. Would have to figure out what voltage the OEM button is expecting and test the output of the wire. Might be able to be rigged with a relay or something.
Good luck! Wishing there was a remindme bot on this forum now...I just emailed them to ask about the replacement control box. Hopefully they'll take care of us early adopters of the V2 kit.
You are absolutely correct - the pinch issue is now solved in firmware, but a new control box will be needed.
We will send you one as soon as they arrive to our warehouse in the next 1-2 weeks.
