DIY Power Lift gate for Tesla Model S Walkthrough Video
Discussion in 'Model S: Interior & Exterior' started by BigTonyTones, Jan 30, 2017.
  1. 1tsla
    1tsla Member
    Fresno, CA
    I guess I haven't been patient enough yet. Will try again this weekend.
    Makes sense. I was in the process of removing the speaker grill last night but had trouble removing that and gave up since it was late. I will try again this weekend. Hopefully with success.
  2. ivolodin
    ivolodin Member
    Boston, mA
    Before installing, I took apart controller module, to see if I can disconnect the speaker, unfortunately, it doesn't use a speaker, it uses buzzer that's embedded into the board. I would imagine you can disconnect it, if you are good with electronics and soldering iron, but it's tough, and I didn't want to damage controller board. Don't think taping it over would help much either.
    That's not the right one. This is male, and you need female for the button. You will still have to shave off some plastic from each side, because it doesn't fit as is into the button connector. You can buy regular computer fan extension cable, they cost around $2. I removed the pins from inside of the connector, cut the wires and soldered in wires from the original button to the pins, then reinserted them. Crimping them didn't work for me, cause they were already cramped and I couldn't open them.
    • Informative x 2
  3. johnzhang22
    johnzhang22 Member
    Sunnyvale
    Just installed the power liftgate by COzero today. It works pretty well, and the beep is not as annoying as I thought it would be. Does anyone know if there's a way to adjust the height of the opening like the OEM PLG, or is it just a simple all the way and all the way down liftgate system?
  4. COzero
    COzero Member
    Stockholm
    Hi John, you can adjust it the same way the factory power liftgate is adjusted - just open the trunk to the desired height, and long press on the inner control button until you hear a confirmation beep.
    Let me know if we can help you further in any way!
    Best regards,
    COzero Team
  5. Sm4llz
    Sm4llz Member
    Colorado Springs, CO
    i have the lighted rear applique and also a tsportline spoiler and am worried it will be cause this to not work properly. Anybody tested with "more weight" added for functionality?
  6. BigTonyTones
    BigTonyTones Member
    Los Angeles
    The seller has two versions available if you have extra weight on the rear. Just message them when buying.
    Also, you can now buy it at autoease.com
  7. johnzhang22
    johnzhang22 Member
    Sunnyvale
    Hi,
    Thank you for the response. I'll try it later today. The height adjustment option was not in the instruction manual. I've noticed that it is difficult to pause the liftgate, it either wants to go all the way up or down, and the force is stronger than the OEM liftgate.
  8. shrink
    shrink Supporting Member
    Phoenix, AZ
    Wow. Great thread! Thanks for posting this. I had no idea this was possible. I just ordered the kit. From my younger DIY car stereo days, I'm notorious for breaking clips when removing panels, so I'm glad this kit comes with some replacement ones.
    I'll review all these great instructions and videos before attempting installation. I'll likely be back here asking for help at some point.
    Will update once everything arrives.
  9. DaveMUK
    DaveMUK Member
    Bicester, UK
    Hi,
    Does anyone know if the autoease kit is the same as the cozero one? Cozero have some massive price differences between their international store and the EU store, the international one works out at £200 less than the EU one but won't let me ship to the UK, the autoease site will so works out much cheaper but just want to make sure it's the same before ordering.
    Thanks!
  10. BigTonyTones
    BigTonyTones Member
    Los Angeles
    They are the same kit
  11. shrink
    Phoenix, AZ
    That was some insanely fast shipping from COZero. Ordered 6/14/2017, shipped out 6/15/2017 Sweden. It arrived just now (6/19/2017) in Phoenix, AZ USA. Wow.
    Hopefully I have some time this weekend to take a shot at this!
  12. Akikiki
    Akikiki A'-Lo-HA ! y'all
    Kaneohe
    #111 Akikiki, Jun 19, 2017
    I removed mine a couple of times on my '13 and '17 - by myself. The tricks I learned is use short bungie
    Okay, where did you go? Who needs the connector that plugs into the switch Tesla Part number 1010327-00-A for the liftgate control switch? Three pin connector with an offset? Looks like those colored wires are bright blue, black and white with brown stripe.
    Need that connector?
    1-1718346-1 TE Connectivity | Mouser
    And I think you are going to need these pins. This is harder to find the right ones.
    963715-1 (Cut Strip) TE Connectivity / AMP | Mouser
    These must be purchased in min of 100 items in cut strips. At 11 cents each that's not as bad
    as the same part number from same company that are sold only in lots of 10,000
    Here's another that looks like they are the same pin size. These too are min 100 cut strip.
    Priced a little higher at nearly 16 cents each.
    928999-1 (Cut Strip) TE Connectivity / AMP | Mouser
    You owe me a dollar or cup of coffee. ;)
  13. rocketshipp85
    rocketshipp85 Member
    MD
    Hey guys I just finished doing an OEM power liftgate retrofit on my 2013 model S. It took a little bit of work and to find where all the necessary parts went but everything is working stock other then on the MCU it shows that the truck is open all the time, anybody know how to fix that?
  14. Akikiki
    Kaneohe
    Have you tried a deep reboot?
  15. rocketshipp85
    MD
    I did the reboot where I hold down the two control wheels on the steering wheel, if there any other one? It looks like the trunk sensor is not working does anybody know where it is and what part number it is to replace it?
  16. Akikiki
    Kaneohe
    Yes, there's a deep boot for the center console. Hold your foot on the brake, then press and hold the control wheels until the boot starts. Then you can release the brake.
    There's also the dash reboot. But that message is not coming from there. That's the upper buttons on the steering wheel. No harm doing those, but it probably not coming from there.
    You should also go an perform a cycle of the liftgate too. Include setting the height too. Its just exercising all the functions to insure they get a reset so-to-speak.
  17. AMPUP
    AMPUP Member
    Dunn Loring, VA
    Did you change the hatch lock? The auto hatch has a different lock that is activated when closed (it pulls the liftgate in like a ratchet rather than the standard one which just latches on a firm close)
  18. shrink
    Phoenix, AZ
    I didn't even realize that was an option. Any chance you have a part number handy for the auto hatch lock?
  19. AMPUP
    AMPUP Member
    Dunn Loring, VA
    No I don't, you should however confirm what I have stated with your SC. The reason I believe this to be the case is just comparing how a non motorized liftgate closes to a motorized one, you hear the lock ratchet and pull the liftgate in. It would explain why you are seeing the behavior you're seeing. Is the liftgate fully closing and locking or do you need to push down more for the screen to show it's actually closed?
  20. shrink
    Phoenix, AZ
    So, I got most of the main wiring done, but need some help to wire other OEM button.
    Anyone know these wires map to the OEM button?
  21. BigTonyTones
    BigTonyTones Member
    Los Angeles
    If the wire map is not in this thread its in the other one. Power lift gate DIY possible?
