  • TMC Podcast #11 will stream live Saturday at 1PM PDT. We will be joined by special guest JT Stukes, a former engineer at Tesla. You can watch it live and participate in the chat on YouTube. We will addressing viewer comments and questions. For more information, follow the TMC Podcast #11 thread.
DIY PPF (HOW TO)
Evening folks,
Today is part of a 2 part DIY series (PPF and Mud Flaps).
If you happen to have a hobby vinyl cutter sitting around and a computer you already have all the tools you need to make your own PPF.
Finding the right thickness and brand for a good price requires more patience and research.
I settled this time for 10 mils 3M Llumar vs trying to source the factory 13 mils (can always double stack later).
Llumar 10 Mil Clear Paint Protection Bulk Film Roll 6 inches X 84 inches https://www.amazon.com/dp/B07D4R7BM...abc_X19SZ24C4MQGCHEVVXK2?_encoding=UTF8&psc=1
$15 US got me 6” by 84” (152mm by 2.1m).
My goal is to create my own rocker panel PPF to serve as a backup for if a mud flap fails to capture some spray later.
The first step is to measure the area you wish to cover, I used twine to capture contours and a protractor to record a few angles, I then cut a rough template from a sheet of paper with sissors and test fit:
It looks rough but it will give you a rough idea.
Next using the dimensions recorded I sketched out a design in Fusion 360 (not the ideal choice but you can use whatever you want).
And finally using your printer cut out some test templates with whatever spare material you wish. I used paper
Now for the fun part, the real print:
To install I just used a bottle filled with water and a few drops of baby shampoo (gentle eyes) and a felt tipped squeegee that came with a phone screen protector install kit.
Installation is pretty simple, just first prep the area by removing any soft waxes or detailer…
Then soak the area in the baby shampoo solution and soak both sides of the PPF as well, place it in place and then position and squeegee. (Lots of YouTube videos on how to do this part)
Anyways here is the finished product:
(Factory top, mine bottom)
It’s not 100%, I could have done better with placement and stretching the contours so it would all line up perfectly, but it cost me $14 and an afternoon of my time to learn… will keep practicing.
Reactions: iyordanov
Follow up: Don’t forget to re protect the area around where you stripped the wax.
Also… In my final self destructive move here, and I’m sure there is going to be a collective gasp..
I call these … courtesy strips.
They give passengers a target to touch when closing the door that both protects the door and also prevents them from wanting to touch the black trim or window to protect the finish.
And yep you can see them.
I’m up for any better ideas?
Reactions: GeoG
iyordanov
Global Vendor
May 31, 2021
403
722
Bay Area
Nice one :) This is similar to how we do them but with a Graphtec plotter.
If you don't have the time or equipment to cut it yourself, you can get them (even bigger) here:
Great job documenting. Wish I could be this adventurous. 😀😀
