DIY Spare Tire Kit
tk1971
84
77
Pasadena, CA
My DIY 2020 Model Y LR AWD Spare Tire kit:
1) Spare tire from a 3rd Gen Nissan Murano. 18x4 steel wheel, 5x114.3mm (or 5x4.5”), and 66.1mm bore. The Stock Nissan spare tire size is T165/90R18 and has a diameter of 29.69”. My stock 255/40R20 has a diameter of 28.03”. I may have a tire shop put a T165/70R18 for a diameter of 27.09”.
2) Chevy S10 pickup or Blazer emergency scissor jack. This one has the little domed protrusion that fits the Tesla’s jacking point. I know of this jack because I was the first to test fit this jack for my Chevy Bolt which has similar jacking points (on the ChevyBolt forums).
3) Chevy S10 / Blazer tire iron with 21mm (13/16”) hex lug wrench.
I test fitted it this morning using all the hardware listed above and drove it around the block a couple of times to make sure everything works.
I only tested it as a rear wheel, as I didn’t test fit it in the front, so if I have a flat in the front, the first thing I will do is to swap the rear to the front then install the spare in the rear.
I also made a little tool to remove the center cap from my 20” wheel.
2jEfnGG
E_R_N
125
75
Vancouver
How do you store it in the car, just laying on the deck in the back? I have this urge to remove the frunk liner and mount a spare and jack in there for road trips though I have only ever needed a spare once in my life so haven't found the need strong enough yet to justify it.
tk1971
84
77
Pasadena, CA
I’m waiting for a vinyl spare tire cover to arrive then I’ll start figuring out where to put it. I noticed that the sub-trunk also has a liner. Maybe there’s room in there?
If there isn’t room for it anywhere to hide it, I may have to lay it right on the trunk and somehow secure it. Maybe I can flip it over and use it as part of some kind of cargo organizer?
wr200man
Southern Iowa
Interesting experiment. I have a kit on back-order from Modern Spare...I will do a comparison once it comes in.
I'm curious about the load capacity of the tire (the MY is pretty heavy) also that of the scissor jack.
Reactions: Brown1428
tk1971
84
77
Pasadena, CA
Yeah I was going to order a Modern Spare, but they have the kits on backorder. This would be the ideal solution.
I had a planned trip so I needed it sooner. Doing all this extra homework looking up wheel center bore sizes, bolt center diameters, minimum wheel diameters, caliper clearances, vehicle weights, tire/jack ratings, and going around buying random pieces to assemble this kit through trial and error is not ideal. In the end it worked out.
The Goodyear T165/90R18 is rated at 2,149 lbs max load (from the tire).
For the tire, a Nissan Murano SUV weighs 3,823 to 4,137 lbs (Google).
A Model Y is 4,416 lbs (Google).
4 tires x 2,149 lbs would be 8,596 lbs. I don't know if the math is that simple, but this spare tire should be fine for the Y.
For the jack, a Chevy Blazer weighs 3,782 to 4,287 lbs (Google).
tk1971
84
77
Pasadena, CA
Got an update on this.
I recently got a 19” alloy spare tire from a Hyundai Equus with a T155/70-19 tire. The tire has a 1150kg / 2536 lbs limit which is enough given the MY GVWR / GAWR FT/RR of 5302 lbs / 3004 & 3306 lbs.
This tire also has a diameter of 27.5”, which is only 1/2” less than my stock 255/40-20 tires.
I also found a way to stow the spare without losing too much cargo space. I removed that one platform covering the shallow storage space up against the rear seat backs to get me a couple of inches. I then stored the tire tools in that shallow area and used a ratcheting tie-down to secure the spare against the rear seat back. I then put my cargo organizer in front of the tire and I’m done.
