chadol
Just done it last weekend.
I used two jacks: a scissor jack and a floor Jack together.
Can't balance without their machine though. And believe it more important than just rotating the wheels.
Extreme case of OCD??You don't need to rebalance a wheel at every tire rotation. Why do you do this?
why you do tire rotation? why people change oil filter on their ICE cars?You don't need to rebalance a wheel at every tire rotation. Why do you do this?
First of all, you don't need to rotate tires. Also, if you don't change oil filter, it will not be able to filter the dirty oil, so higher risk of engine failure and/or reduced engine performance.why you do tire rotation? why people change oil filter on their ICE cars?
The point is not just an isolated "why" for tire rotation and balance. The point people are making is that tire balance does not need to be done at the same frequency as rotation (in most situations you don't need to balance it after the initial balance), and they don't get why rotation and balance were mentioned in the same argument.why you do tire rotation? why people change oil filter on their ICE cars?
Wouldn’t it be safety? To use just a floor jack and no stands isn’t recommende. I get we are all YouTube mechanics and teslas are the bestest of all bestest Goodest vehicles, people should use floor jacksI think it creates a lot of unnecessary work and risk trying to get all 4 lift points supported by pucks on 4 jack stands or transferring to the lower control arms as done here. Why do this? Are you concerned that the car frame will bend of break? I prefer to use a single puck for the whole job. Once on the left side, and then once on the right side. This is the way Tesla mobile service does it. This only permits front to back rotation, but that is fine. A second jack or stand can be used under the unused same-side lift point for added safety.
I DIY a lot of things on my cars, but tire rotation/balance is not one of them. Walmart is $56 lifetime nationwide (used to be much cheaper), I don't see a reason do it myself and can't balance the tires.
what are the reasons you guys rotate yourselves?
. . . and the jack-stands go under by the wheels.
Cause that's where the shock/strut and spring that hold up the weight of the vehicle is?I thought this a good post. However, how do you know the place you put the jack stands is a good one for holding the weight of the vehicle?
For me it is faster to rotate myself at home. Walmart is 15 mins away, and there might be a wait too. Takes me 15 mins for simple front to back rotation.I DIY a lot of things on my cars, but tire rotation/balance is not one of them. Walmart is $56 lifetime nationwide (used to be much cheaper), I don't see a reason do it myself and can't balance the tires.
