Closer and more UV bulb or LED wattage will cure faster, but further distance and/or lower wattage will cure eventually. Direct, unfiltered sunlight will also cure eventually, but at a much slower rate. I set mine box up for unattended full screen coverage and had my UV LED bulb far enough away from the screen to cover all of it. I also lined my box with aluminum foil for reflection (being careful not to allow the foil to get near the bulb socket). Full cure (as far as I know) was a total of about 12 hours with this setup. I will find out for sure if it was fully cured next summer when it warms up. If the yellow returns, I will cure it some more.
