It could be that the brake caliper is the same part painted red. If it is mounted further from the center of the hub with a larger rotor and a different pad compound it would be a higher performance design. I believe that is what Honda did with the Acura Integra Type R vs. other integras. I have bolted up 17” wheels on the front that wouldn’t fit on the rear. So there is room for the larger rotors FN01 mentioned that could fit inside an 18” wheel.
