YusufT
I don’t get why this thread exists. You should use FOG lights when it’s FOGGY outside. There’s a reason the car won’t turn fog lights on automatically.
Why do you do it manually, when you can have it done automatically?
I usually agree, but on the 3 they are so tiny and integrated into the led strip below the headlights, so they don’t scream, my fogs are on with no fog!
Are you talking about a rear fog light? We are discussing the front ones that aren't very bright.Illegal here in Australia to drive with your fog lights on unless there's fog.
I've been pulled over for it.
The brake light actuator doesn't seem to be affected by the level of g force generated by regen braking.
I do lift gently but the brake light came on at the same pedal position during my experiment. I was disappointed to see that also.
You should test it sometime.
I'm not a person that does things for how it looks to others. I do it for function when I need it. I'm not annoyed to see it on other cars.I'm curious of the communities consensus on this. Personally I think that fog lights in general make the front fascia on the Model 3 looks nicer especially during/after sunset. Would like to know if others would think this is annoying or not.
Thanks
Front fog lights.What is the problem with using fog lights at night? They aren't distracting or interfere with traffic. They are useful if you live in areas with deer, etc.
Why would front fogs be illegal to use? They point down and out, so they don't impact other cars. I've heard of rear fog, since it is extremely bright and only for bad weather.Front fog lights.
In most North American jurisdictions, it's illegal to use fog lights without the headlights being on--even in the fog. So the fog lights are rendered useless. Also many fog lights are not adjusted correctly and do impact other drivers.Why would front fogs be illegal to use? They point down and out, so they don't impact other cars. I've heard of rear fog, since it is extremely bright and only for bad weather.
I don't know, perhaps fog lights used to be brighter and the law persists?Why would front fogs be illegal to use? They point down and out, so they don't impact other cars. I've heard of rear fog, since it is extremely bright and only for bad weather.
As an example, when going down a relatively steep hill, you can maintain speed with your foot nearly off the accelerator. There is no brake light triggered when maintaining speed. Only when decelerating to a certain g.Brake lights are triggered by accelerometer not amount of regen although there is probably a correlation between the two. It turns on brake lights when deceleration exceeds certain amount.
I thought the fog lights do turn on automatically if the default is selected for fog lights to be on.I don’t get why this thread exists. You should use FOG lights when it’s FOGGY outside. There’s a reason the car won’t turn fog lights on automatically.
