Do you have shudder on hard acceleration? AKA death rattle?
Discussion in 'Model S' started by dk10438, May 18, 2019.
  1. Yes- Performance
    79 vote(s)
    26.9%
  2. Yes- Non-Performance
    122 vote(s)
    41.5%
  3. Have no idea what you're talking about.
    22 vote(s)
    7.5%
  4. No-Performance
    28 vote(s)
    9.5%
  5. No- Non-Performance
    43 vote(s)
    14.6%
  1. Landen420
    Landen420 Member
    Southern California
    DO NOT TRUST TESLA WHEEL ALIGNMENT!
    So I had a wheel alignment done this am at a performance shop because I recently threw some new wheels on my car and the driver side wheel was rubbing the front of the wheel well. Whats funny is that just 2 months ago, I had Tesla do a wheel alignment because i noticed some veering. Well, they fixed the toe and camber which fixed the veering but didn't align the castor which is part of a "wheel alignment". It just amazes me the half ass job they do at their service center.
    After my alignment this am, the rubbing was mostly gone and only rubs in reverse at full lock but that is because I am running 255/35/21 in the front which is a smidge above the max.
    Imgur
  2. Silicon Desert
    Silicon Desert Active Member
    Sparks Nevada / GF 1
    yes that is what I meant. Glad you had it checked.
  3. dustinvogel
    dustinvogel Member
    Almere
    This is my before (so, after Tesla did it) and after.
    Actueel = After
    Vooraf = Before
  4. van2157
    van2157 New Member
    Reno
    I experience this in 2019 Model X with air suspension. My house is located on a hilly, bumpy, dirt road and the suspension is set to high when leaving the house. I have a knocking in the front driver's side tire. Once on paved roads, the suspension is lowered to standard, knocking stops. I then have to take off from a dead stop onto a highway, which usually means hard acceleration. This is where I felt the strongest of "shudders." It was taken in for an adjustment and the shudder problem from a dead stop to hard accelerations has been resolved, but the knocking on the high setting on the hilly, bumpy, dirt road has returned. I'm looking into purchasing a Model S with air suspension, so I guess this problem will turn into a general maintenance issue for my vehicles. That's what I get for living out in the middle of nowhere. ;)
  5. TSLA Pilot
    TSLA Pilot Active Member
    United States
    How was this resolved for you?
    Did you get a new car or your money back or a fix?
    Thanks!
  6. AWDtsla
    AWDtsla Active Member
    NE
    Does anyone know if they solved this problem for Model 3 and Y?
  7. TSLA Pilot
    United States
    I've actually never heard of the M3 or MY having this issue?
    Is this a "thing" or just a concern that they might?
  8. AWDtsla
    NE
    Well, I half expected the "problem" to be fixed in my new Model S, which it clearly isn't. Actually comfort mode in the suspension makes it worse, since there's more front-end lift under even mild acceleration. A problem in itself which without hardware changes could be compensated for in software, IF engineering was not oblivious to the issue.
    So, I wonder about the state of 3/Y. Especially since it's likely that Y has a higher halfshaft angle.
  9. rustybh1
    rustybh1 Member
    Bow, WA
    Had both my front axles replaced on my 2020 MS LR, then had to have a front wheel speed sensor replaced about 2 weeks later........
  10. Jamojones
    Jamojones Member
    Park City, UT
    I have a 2020 Model X with all the exact same issues I've seen others describe. I've seen the service bulletin dated June 25th 2019. I am currently scheduled for service and it looks like TSLA is doing this half shaft repair AGIAN. This is the 2nd time in less than a year on something thats about a year old. Have TSLA or any other owners come up with a better solution than repeatedly having these half shafts replaced? As long as TSLA is paying for it they can do it every month, but what happens when my warranty runs out? I shouldn't have to pay for this problem.
  11. ragweedd
    ragweedd Member
    Boynton Beach
    I have the same problem with my 2020 Model s. Parts are on order and planned repair in replacing both half seats next week.
  12. TSLA Pilot
    United States
    You're lucky--my local SC won't even bother to replace them.
    However, I don't like hearing this garbage on nearly every high power acceleration so it's going back for a replacement, or so I'll be demanding. I don't really care that it might happen again, or if they have to schedule a fix every few months--perhaps that'll serve as an incentive to fix the damn problem once and for all?
  13. FatherTo1
    FatherTo1 Member
    I have had both front half shafts replaced twice (March 2020 and October 2020). Unfortunately, shudder still persists despite driving on Low suspension setting after the last replacement. The shudder occurs even during moderate acceleration. I will wait to see if the next redesigned parts offer a permanent fix for others.
  14. P100D_Me
    P100D_Me Member
    Australia
    Consider doing what I always do with cars, sell before the warranty runs out ;)
