Do you pressure wash your Model S?
Discussion in 'Model S: Interior & Exterior' started by steilkurve, Mar 30, 2015.
  1. steilkurve
    steilkurve Member
    Montreal, Canada
    About to conduct the first wash of my Model S. Should I use my pressure washer given it's aluminum and I hear the paint is softer.
  2. Sigma4Life
    Sigma4Life Member
    Dallas, Texas, United States
    If you mean the typical sprayer at self car washes then yes, I washed my pearl white P85 for over a year that way and never had any issues. I would spray it down but use my own wash mitt and bucket.
  3. FLDarren
    FLDarren Member
    Seminole, Fl.
    I use a Ryobi electric pressure washer. Works nicely. Never had any issues. I hold it 6-12 inches from surface of car. I have a foam cannon I use and run over the car with a microfiber wash mitt.
  4. iadbound
    iadbound Member
    No. VA
    I've used a pressure washer many times without incident. The manual specifically discusses the use of pressure washers. It suggests that you don't aim it at the windows; keep a distance of 12", etc. Check page 109 for more details.
  5. Kbsilver
    Kbsilver Member
    Central NJ
    Agree about keeping a good distance. A detailer once used a pressure washer too close on one of our vehicles (Ford) and blew the paint right off the plastic bumper cover.
  6. pgiralt
    pgiralt Supporting Member
    Cary, NC
    Using just a regular hose gets water into the reverse lights. Can't imagine what a pressure washer would do.
  7. kevincwelch
    kevincwelch Active Member
    Chicagoland
    I have a few words of caution. I use the pressure sprayer all the time (Greenworks 1.7). However, I took my car to a touchless car wash last winter and I sustained a leak around the C pillar near the window. Not sure if this is due to the frameless nature of the window, but I never have experienced this with any other frame less window. It was sealed by Tesla, but I have since avoided pressure spraying around the windows.
    I wouldn't worry about blowing paint off or damaging the vehicle, but when I'm
  8. Dborn
    Dborn Confirmed
    Sydney, Australia
    I use a Gerni sprayer all the time. No issues, but I do have Opticoat. Occasionally get some water in the reflector for the reversing light. No biggie. It dries over a day or two. Service centre assures me no water gets into the light fitting itself.
  9. steilkurve
    steilkurve Member
    Montreal, Canada
    Thanks all. Delayed my first wash 'cause it wouldn't stop snowing and raining over here. But this weekend is it. Here's what I'll do to try and keep my black P85D pristine:
    - Hose down pano roof and windows.
    - Pressure wash bottom half at a good distance.
    - Foam the car.
    - Hose down.
    - Foam again.
    - 2-bucket wash.
    - Rinse.
    - Blow dry.
    I know this may sound extreme, especially the two foaming, but it is really dirty and I want to minimize dirt rubbing off the clear coat.
    Thoughts? Have I gone off the rails?! ;-)
  10. svp6
    svp6 Member
    MN
    I only did touchless washing for last 3 months. Few drops of water at the small triangular window driver side, nothing impressive - will have it checked when I get my new seats installed. Obviously no undercarriage wash.
  11. kevincwelch
    Chicagoland
    Not sure doing the two foam steps is going to help you. If you're using a high quality soap in your foam lance, it's not alkaline enough to start breaking down the grime. I'd use the foam to lay down a thick layer of suds and lubricity to help with the two bucket wash.
    Having said that, I like everything else, especially the blow dry.
