Do you recognize this type of plug?
Discussion in 'Model S: Battery & Charging' started by Malibuscott, Sep 27, 2013.
  1. Malibuscott
    Malibuscott Member
    United States
    and is there an adapter available for the Model S? thanks in advance
  2. bradc
    bradc Member
    Seattle, WA
  3. Malibuscott
    Malibuscott Member
    United States
    Thank you bradc
  4. captain_zap
    captain_zap Electron tamer
    Redmond, WA
    #4 captain_zap, Sep 28, 2013
    Beware of the receptacle wiring, though. This receptacle has two 120V hots (supposed to be opposite legs) and a neutral, giving either 120V hot to neutral or 240V hot to hot. As a boat owner I can tell you that many of these receptacles are wired with two 120V hots of the same phase. This works because most boats do not use 240V, they just want two 120V circuits. So a standard 14-50 adapter will not work with the model S in this situation since it gives zero volts hot to hot, and a modified adapter (using hot-neutral) will only get you 120V at 13A or so, instead of 240V at 40A. You can test it with a voltmeter to see if any combination gives you 240V.
