Do Your Brakes Emit a Cheap Sounding Squeak?
Discussion in 'Model S' started by theslimshadyist, Dec 27, 2016.
Tags:
  1. theslimshadyist
    theslimshadyist NashVegas!
    Franklin, TN
    How do I even explain this one, I dunno but I'm gonna try. This happens after I've had the car out in the rain, even arriving back home and letting the car sit for hours. For example, if I'm driving the car into the garage and start to ease on the brakes, everything is fine until I press them hard enough to fully stop the car and then the brakes will emit this gawd awful "cheap" high pitch sounding squeak/chirp. I mean, it sounds like toy brakes. After the car dries out for a good day, I repeat the procedure at home, a stop light, etc. and I don't have this issue.
    So, it appears that it's something to do with the moisture and good gosh, it's fairly loud and just sounds like junk. I get this look from people like, "WTH is that noise all about?", kind of embarrassing to be honest.
    Have any of you experienced this?
  2. theslimshadyist
    Franklin, TN
    Here we go.... this right here is pretty much spot on!
  3. wamochi
    wamochi Member
    San Diego, CA
    yes, just as you described
  4. number12
    number12 Supporting Member
    Tesla
    Does your car have 6000 miles?
    If not they are not set. Regen extends break in period
  5. number12
    Tesla
  6. rory breaker
    rory breaker Member
    TX
    So after 6k mikes this goes away? Can someone 100% confirm that from their own experience?
    • Disagree x 1
  7. theslimshadyist
    Franklin, TN
    I assume that you are experiencing this as well? lol
  8. theslimshadyist
    Franklin, TN
    Ummm, better get to a wall your iPhone is about to go dead. ;)
  9. theslimshadyist
    Franklin, TN
    Ok, I get the 6K mile theory but I'm curious as to why this ONLY happens after I've driven the car in rain. I guess the brakes and rotors aren't "waterproof"? :eek:
  10. number12
    Tesla
    I would think it's the same reason they might look "rusty" after rain. Then rust off after using them. Mine squealed for a bit so I used brakes on purpose couple times and then it went away.
  11. DarkMatter
    DarkMatter Member
    Olympia, WA
    Bed in the brakes. This is pretty common for modern car brakes if they have not been bedded in correctly.
  12. demundus
    demundus Active Member
    Oceanside, CA
    Because you rarely use the brakes. They oxidize and take longer to return to "ICE" status. After a good rain, my car even "sticks" a little when i first go from park to drive, as if the rust was so intense it was holding the car back for .00000001 seconds. I'm nearly 100k miles and haven't had a brake problem yet. :)
    • Informative x 2
  13. theslimshadyist
    Franklin, TN
    Great idea, I will try bed-in the brakes tomorrow.
  14. DrivingRockies
    US
    I have just over 5k on my X. Noise is just beginning to subside.
    • Informative x 2
  15. ev-now
    ev-now Member
    Denver, CO
    9K on 2015 S60 - have not noticed this. Though I have noticed the 'seized on' behavior when the rotors are wet when the car is parked. Have not investigated how to get it to park without applying emergency brake - not sure if it can.
  16. doubleohwhat
    doubleohwhat Member
    Alabama
    I've never had this occur on my S60 but it is a common thing with new vehicles. My prior two vehicles were BMWs and they both had this issue for the first month.
  17. John Stuckey
    John Stuckey Member
    Dayton, Ohio
    6,000 miles is a fair guess. Could be more if you use regen a lot. Our noises went away at about 8-9000 miles. And then I was involved in an on-purpose (humaniod ran a red light) wreck and the left front brake was replaced. The brake noise, left front, is back again for another 8-9000 miles :)
  18. AoneOne
    AoneOne Member
    Fox Chapel (Pittsburgh), PA
    Follow the instructions for towing to shut down without setting the emergency brake. Of course, it will roll like a skateboard without the parking brake, so chock your wheels (or park on very level ground).
  19. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    American worry about their brakes squeaking to the point that manufacturers put crappier brake pads on them. Compare the brakes on German cars in Germany versus over here. Noisier and better versus quieter and crappier.
    Also, after rain the rotors sitting overnight tend to rust slightly, and that makes them squeak until the pads clean them off. Tesla cars make much less use of the brakes so they don't get cleaned off as quickly.
  20. Peteybabes
    Peteybabes redneck drivin' a tesla...
    'murica
    This may simply be because you have a performance model with better brakes and performance pads...i had squeaking from day one on some performance pads on a previous car once.
    this just a theory :)
