Hey so being that its winter now been trying to determine best way to heat the rear cabin.
1. I'm finding the rear central vents(behind front center arm rest) do not blow equally, more Air comes out of the left vent is that normal?
2. If the heating mode is on auto and is going to the feet, Do the rear cabin get any air? Or does it only come through the front bottom vents?
3. Do the Side rear vents ever get really warm? They only seem to get mildly warm and are kind of an annoyance as you cant even turn them off manually if your in the rear. Are they working properly? Do they get hot for others? There is a separate temperature setting for back but doesn't even compare to front...Are you guys finding the same
4. Do your rear heated seats heat as well as your fronts? Finding fronts heat the bottom butt area but not back area. Backs heat both butt and back but not as hot.
Let me know what you guys think...Thanks
