Dodge Circuit EV (Lotus Europa conversion)
Discussion in 'Electric Conversions' started by doug, Sep 23, 2008.
  1. doug
    doug Administrator / Head Moderator
  2. doug
    #2 doug, Sep 23, 2008
  3. Laurent
    Laurent Member
    SF Bay Area
    I like it. What's the word on pricing and availability ?
  4. doug
    The form factor of the batteries seem to be similar to what's being used in that Exige Wind Car.
    Looks like the power electronics require water cooling. Unclear what kind of temperature management the batteries have. The snap-on ferric beads look kinda kludgy.
  5. dpeilow
    dpeilow Moderator
    Winchester, UK
    So, is this a one-off PR stunt or serious? I wonder if Lotus did supply a glider or if this is a true conversion. I guess Lotus are free to deal with who they like but it must be a bit close to home for Tesla. Interesting nonetheless.
  6. doug
    Chrysler Provides Details on New 'Electric Cars' - News and Analysis by PC Magazine
    Chrysler unveils electric cars, stumps for loans | Reuters
  7. TEG
    TEG TMC Moderator
    None, other than some estimate that it will hit the market "in a few years" and the statement that it should "undercut Tesla".
    Doug - thanks for whipping together this topic and finding the pictures. This is an interesting happening. I sure hope they follow through and build this since Roadster prices seem to keep going up every time I look.
    Some spec questions I have already:
    #1: Sometimes listed as under 6s, and other times as under 5s.
    #2: Pack mentioned as 26kWh but claims of nearly 200 mile range. Could it be that much more efficient than the Roadster? (1/2 the pack capacity but 3/4 of the range?!)
    #3: Recharge in 8 hours from 110v, and 4 hours from 220v. That doesn't make sense to me. Typical 220v connections are usually twice (or more) the amperage of a typical 110v connection (e.g.: 35amps vs 12amps), so typically 220v is more like 4x faster to recharge. I would think more like 3.5 hours from 220v, 20 hours from 110v.
  8. TEG
    TEG TMC Moderator
    Good question! I wish I knew the answer. Time will tell.
  9. doug
    #9 doug, Sep 23, 2008
    Good question. I think the word is that there is no word yet.
    Hard to know if they're serious or not. But I'm sure part of their calculation to use the Lotus body is to steal some of Tesla thunder and to generate headlines.
    How does one define a conversion? Must the car have actually had an ICE in it at some point, or is it enough that the glider was developed for an ICE vehicle.
    I'm curious if Tesla had a heads-up about this. It definitely adds another wrinkle for the PR department. People will ask how the Roadster is different from this "Dodge" EV. The Chrysler PR will try to equate the two. But those in the know realize that the Roadster was a heck of a lot more work. Bad enough that there are still those that think the Roadster is just a converted Elise. Additionally, there are those that will think this car looks better (read faster) than the Roadster. The front of the Europa is more busy, perhaps more aggressive than the Roadster without being insectoid like the Elise.
    I've been looking at Roadsters for so long, the Europa looks like a fresher natural progression.
  10. doug
    Siry responds:
    Chrysler charges into electric car race - Los Angeles Times
    This illustrates how the press will call both cars "based on a Lotus platform."
  11. TEG
    TEG TMC Moderator
  12. doug
    #12 doug, Sep 23, 2008
    In this vid, when they show the "engine" bay, you see a carbon fiber cover hiding the name of the motor manufacturer.
  13. DaveD
    DaveD EVs Kick Gas!
    Redmond, WA
    Same Connector as Tesla?
    Is it possible that they're using the same power connector (SAE J1772?) as Tesla?
  14. graham
    graham Active Member
    Aptos, California
    This is a good catch! More hope that public charging stations may support the plug the Roadster uses.
  15. graham
    Aptos, California
    Motor Trend weighs in with an interesting quotation:
    Dodge EV - Quick Drive - Motor Trend
    I had not heard the claim that they are trying to beat the Roadster before.
  16. malcolm
    malcolm Active Member
    #16 malcolm, Sep 24, 2008
    I'm sceptical about the range of 150 to 200 miles from a 26 kWh battery. That will require some gentle hypermiling rather than the usual Dodge antics.
    If you scaled down the Roadtser's battery to 26kWh while keeping all the carbon fibre and the same transmission, you'd get about 120 miles at EPA combined.
    The Europa/Dodge is less "Tesla Killer", more "Tesla's Overweight Stalker".
    Plus, announcing a Lotus glider conversion is so 2006. :wink:
  17. DDB
    DDB Member
    I suspect many will compare the price rather than weight and performance. This isn't a track car. I for one could care less about a half a second in the 0 to 60 time, but a $20,000 difference in price may persuade me to walk to Chrysler. Moreover, if I take a small hit in mileage, it sucks, but I'll live with it. We all know a few extra miles in range [at least at this day and time in Li-ion batteries] makes for a huge increase in price. It will be interesting to see what Chrysler can sell this puppy for, because as I see it, there isn't much difference than the Roadster with some HUGE benefits. It would be much easier for the masses to service it than a Tesla automobile...how many Chrysler service stations are there compared to Tesla? Price is key.
  18. Cobos
    Cobos S60 Owner since 2013 - sold, S85D owner since 2017
    Oslo, Norway
    After the numbers we get out of Martin it seems range might actually be a big case. Using the Roadster or the Dodge EV as the sports car they are, you can usually cut the EPA range numbers in half. Not that there's anything wrong with that, that definately happens with any Ferrari or Porsche as well, but the range for the Dodge EV might be so short then it starts to become a problem... Which of course might be a serious "problem" if the values of 26kWh battery and the range numbers given are "optimistic".
    Cobos
  19. WarpedOne
    WarpedOne Supreme Premier
    Slovenia, Europe
    This amount of energy simply cannot offer much of sporty range. It is basic phisics. 26kWh suffices for about 100miles of constant 80mph on level road.
    Remember that 61-mile range estimation on Roadster's VDS?
    This number would be around 30 in Dodge EV's case.
    Car weight cannot get much lower, aerodynamics not much better and efficiency is already very high. Range will thus go up only when battery capacities rise. With 100kWh you'd get arond 100 miles of "hard" driving with a car of similar weight and aerodynamics. And around 500miles of "EPA highway cycle" driving :)
  20. dpeilow
    dpeilow Moderator
    Winchester, UK
    Furthermore:
    That seems very conservative, as the numbers are actually very close to my understanding of DT 1.5's.
    And yes, I was also thinking that 26kWh for 150-200 miles range is probably impossible.
    This smells more like a Tesla spoiler than anything that has been properly worked out.
