Does a standard 80" door fit in a Model 3? No problem.
Discussion in 'Model 3: Interior & Exterior' started by beacham, Jul 4, 2018.
  1. beacham
    beacham New Member
    Fort Worth, Texas
    Went to pick up a standard 80" door in my Model 3 today. I was a little worried but turned out very satisfied! Still had plenty of room for the wife and some groceries. Model3_door_back.jpg model3_door_side.jpg
    • Informative x 2
  2. m3tx
    m3tx Member
    Houston, TX
    Can the front seat fold in any way? I sometimes have to buy some 2x4x8' but looks like 96" might be a bit too long for this, unless risking having them an inch from the screen
  3. beacham
    beacham New Member
    Fort Worth, Texas
    I don't think it can fold. However, I actually had to put the passenger seat back a few inches to prop the door up on the top of it. Seems like you could prop up a 96" board similar to the way I did it but to the side of the headrest instead. Not sure how you'd keep them from falling down into the middle- maybe a bungee cord around the head rest?
  4. Butane
    Butane Member
    Bloomington, IN
    Glad it fits doors. I learned the hard way this past weekend that new-in-box Kohler toilets will not fit. :D
  5. M0DEL³
    M0DEL³ Member
    A
    #5 M0DEL³, Jul 5, 2018
    I agree that is a "Fit", but think I disagree that that is a "No Problem Fit".
    This is closer to a no problem fit... Would give you the edge in the event of a heavy rain, but he gets bonus points for including the whole frame... ;)
    Well done on the packing though.
    I think I'd be screaming "Roof Rack" before I'd do too much Door Smuggling in a Model 3.
  6. Tdriver
    Tdriver Member
    Palm Desert, CA
    You could have left the wife at the store and come back the next day to pick her up.
    • Funny x 2
  7. SouthBayGuy
    SouthBayGuy Member
    Nice to know one can fit an entire door completely inside the car. I think if I had multiple doors, I would place the doors flat and let them protrude out the trunk.
  8. M0DEL³
    M0DEL³ Member
    A
    Which begs the question, "Will the Model 3 shift into drive with the trunk open?" and if, so does it have any sort of speed throttling if the trunk is not latched? (Think tied down above a stack of protruding doors.] I assume you get a nag at the least?
  9. SouthBayGuy
    SouthBayGuy Member
    I decided to test this. I was able to drive the car with the trunk open. Initially, the car will chime and give a message on the screen. The chiming will stop but the reminder that the trunk is open will remain. I have not tried this at high speeds. But I don't expect any problems.
  10. Dr. J
    Dr. J Active Member
    Fort Worth, Texas
    Wife was in the frunk. Apparently. :D
