A GFCI is now required by code in a garage or outdoors, kitchen, bath etc. When the condo was built if the GFCI was required at that time it would have been installed. You don't have to upgrade your condo garage receptacle to a GFCI if you don't want to. (The Tesla Mobile Connector already has a GFCI for the charging cord and charging connector.) Sometimes having more than one GFCI on a circuit can cause issues with false ground faults.How important it is to convert a normal outlet to GFCI? My current condo situation limits me to use only the 120V outlet in the garage. So, just wondering if I need to replace it with GFCI.
If the receptacle is more than 5 years old it would worth replacing with a new receptacle. Time, moisture, dirt and corrosion can take their toll and the receptacle may not make a tight connection with the plug. Spend a little more for a contractor grade receptacle. Don't buy the cheap receptacles sold loose from bins. Always use the screw down terminals on the receptacle for connecting the wires. Never use the push in connections located on the back of the receptacle.
