ls7corvete
Good feedback here, the only thing I would add is this: Make sure your outlet and wiring are in very good condition. Pulling power from them constantly puts a lot of stress on older or worn outlets.
I triple this, and add that you should make sure that you know what other outlets or lights are on the same circuit. Find the breaker and turn it off, then go around with an outlet tester to check. No sense blowing the breaker because you didn't know that the same circuit fed the outlet you plugged your mower into.Good feedback here, the only thing I would add is this: Make sure your outlet and wiring are in very good condition. Pulling power from them constantly puts a lot of stress on older or worn outlets.
Thank you all so much for this feedback- it is really helpful. Here is some more context and also reflections on your feedback.
-Pricing: Currently, I pay a steady rate for my electricity-approximately 12.5 cents/kWh (combined generation/transmission). However, I have solar panels that produce, at least so far, 100% or more of my electricity needs. Given the added electrical use that this car will represent, I plan to switch to real-time pricing when the car arrives. My hope is that between times of negative to low pricing (generally overnight when I would be charging anyway), I can mitigate the cost of my additional electrical usage, if it's not covered by my own production from my solar array. My private game will be trying to charge my car for free, of course, making sure I don't end up with a dead battery because I tried to be too clever and save a penny here or there.
-Climate/hardware: I am in Chicago so your feedback on how cold affects the batteries is very helpful. As a result of that, I am having my solar company, which is now doing tesla vehicle charger installs as part of their business, price out what it would be to get a Nema 14-50 plug (that's the dryer plug, right?). I potentially still want to try and make this work without additional electrical work (and trenching since I have a detached garage). Also, the garage is very new so the electrical outlets are all in great condition. All that said, if the battery drain due to the cold weather proves excessive, it will become a necessity to upgrade.
-Distance/Recharge rates: I definitely know I will be shelling out for some supercharger time or extra destination charging in the beginning because the temptation to take people for rides or just drive my car myself in the beginning will definitely be overwhelming. However, as I am close to a major city, I have been able to find many restaurants, hotels, movie theaters, malls, that have chargers that are free. In any event, once my driving behavior settles back to my routine, I have mapped out my commute and it's almost exactly 15 miles each way, 30 miles round trip. Assuming an average rate of charge of 4 mph, I should be able to recoup that distance and any additional drain from A/C, acceleration during my overnight charging time (figuring charging from about 8 pm-7 am or 11 hours). Many days I would start charging potentially earlier than that; however, then I run into the real-time electrical pricing issue. My electric utility practices net metering and I can "bank" unused kWh I produce over a 12-month period so even if the price surges, I should be able to draw from this bank of solar production.
One question that I have for the community:
What is the kWh to mph charge rate? An early responder said 1.1 to 1.2 kWh per hour of charge (figuring an average of 4 miles of charge). Is this about right?
Thanks again for the responses- I realize that I probably have 12 months of wait time in front of me since I made the reservation a few days ago, but it's fun to post on here now instead of just watching. Without a reservation or a car, posting felt like I would be a fraud
Based on what I see in the panel and what I remember from garage construction, the outlet would draw 15 amps maximum and there is one buried conduit going from the house to the garage about 25 feet distance.
My Dryer outlet is a NEMA 10-30. It has no ground. The breaker it is attached to are linked 20 amp breakers. Aren't these supposed to be 30s?
I just made a reservation for a Model 3. Currently my garage has a regular GFCI outlet I think it's 110 volts- I don't have a huge commute max 40 miles a day, round-tip. I was thinking I could slow charge while at home and destination charge on the weekends. Anyone have an opinion on the feasibility of this from experience?
So yes although we are just Tesla wannabe's. (Can't afford one). We have two EVSE's. One is 240 volt 10 KW in the garage (one car garage) and the other is a 120 volt 8 or 12 amp (selectable) that is hooked up to the Christmas light plug. Surprisingly we do probably half our charging with it as Angelas electric smart car is a convertible and quite often has the top down so it goes in the garage at night. Works well.
Kinda all hidden from the street. Stores away nicely.
Here is the 240 juice box. It is plugged into a 25 foot 14-50 extension cord that plugs into a 14-50 plug in the garage. Handy to have the higher power...but not very often. We are 5 minutes from a fast charger so never a panic.
10-30 has a ground. It does not have a neutral. And it should have a double pole 30A breaker on 10 gauge wire, not 2 separate 20s. If one breaker trips, the other can keep sending power, and that's bad.
What model of EVSE is that (the one up near the ceiling?)
Also, I suspect your Leaf uses less power per mile than a Tesla, and since it has a smaller battery to begin with, there is a better chance of a full charge overnight on a 15a 120v circuit. The Tesla may take longer per hour of range regenerated I assume?
Heat kills my gen 1 volts battery very quickly unless the engine is running I tend to use the heated seats mostly (San Diego) unless I need to defrost.I think it could work. But you'd _really_ want to be sure about your main driving.
In summer I don't think it'd be any problem.
In winter it would be more challenging, but as long as you make sure the car is well charged at the end of a weekend, you'd have enough buffer to get you comfortably through the week.
However, just getting some basic 240V charging (even at 240V x 16A) would really help make things much easier for you.
(No Tesla. My commute is 41.3 miles round trip, max speed 55mph; we have a Gen 1 Volt, which is my wife's commuter, but I occasionally get to commute in it in winter; Gen 1 Volt is not particularly efficient. I live in Central Maine which is colder than Chicago in winter).
I think I need to kill the power and see if the wire is 10AWG at the outlet and at the breaker, if it is I can just replace the 2 linked brakers with a double breaker right? like this one? Siemens Two 30 Amp Single-Pole Circuit Breaker Non-Current Limiting-Q3030NC - The Home Depot. That would save a slot in my 200 amp service panel which is full.
With the 10-30 I guess this would be enough to start out with when I get a model 3? (80 mile commute) but I kind of want to get a dedicated charging outlet still eventually I think. I don't have a dryer buddy, but there's already 2 240v outlets (they are tied together). Should be ok so long as I don't charge and dry cloths at the same time?). This all assumes I have the proper wiring, I have a feeling I do not.
