We are remodeling our townhome. It was built in 1981 with 100amp service at the meter which is in a HOA utility closet. The conduit from the closet is 1.5" and buried in concrete. The general contractor says that upgrading our electrical service from 100amp to 150 or 200, would be prohibitively expensive. And that assumes our utility can provIde that servive. He also said that our breaker panel is now full and that we need to replace it. He also says that he doubts that the city will allow us to keep our TWC which is on a 60amp breaker. FWIW, we have never had that breaker or the main 100amp breaker flip off. As part of the remodel I would like to add AC (we get about 1 month of uncomfortable weather where we live).
This brings me to the SmartSwitch 240 that I asked about. It claims to allow 2 devices (e.g. AC and a TWC) to share a single 50amp breaker. It sets up the first device as the priority device and gives it up to 40amps of service. It sets up the other as a secondary device with 32amps of service. The secondary device can only get service 5 or more minutes after the primary shuts off and will be automatically shut down if the primary starts.
This would allow me to set the AC as the primary giving it priority and the TWC as the secondary. I understand the I would need to back the TWC down to 40 amps or even 32amps. However, I am retired and can easily live with the slower charging speed.
Am I missing something that I should consider? I would like to present this as a possible solution to the general contractor and his electrician.
