  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Does anyone have data on how quickly their Black Model 3 cools while in the sun >80F?
pacmanbrodude
2015 Model S, 2018 Model 3, 16.8kW Solar, 3PW+
Nov 13, 2015
27
25
Baltimore MD
The AC in our 2018 Model 3 (blue with white interior) was occasionally failing to cool the car properly, when set on Auto. It wasn't increasing the fan speed as much as necessary. I live in south FL. I had the car serviced, and they replaced a control unit (low voltage controller, left), which resolved the issue, under warranty.
Good thought. Appreciate all the ideas. The vent fan definitely adjusts on auto though. Usually it hovers at around 9 out of 11 then lowers a couple as it approaches (but almost never reaches) set temperature. In fact, my wife frequently takes it off of AUTO and lowers the fan speed - understandably because if the car doesn't cool down much anyway, why bother having the fan blasting loudly?
I'll add that the AC does work. It can bring the temperature lower than the outside temperature. It also can reduce humidity in the cabin to help defog the windshield. How well it works? Well... not very well.
Anyway, hopefully they can figure out what's wrong next time. The service center said they will have to schedule fixing it on another service visit so I'm going to pick up my car today.
pacmanbrodude
Nov 13, 2015
27
25
Baltimore MD
I took it into a different service center. They definitely tried much harder at finding the problem. They just updated me today:
Main HVAC duct bleed actuators are not functioning properly so when the A/C is on the system is
partially still sucking warm air, not cooling the car properly. Since both actuators had faults and has
been a repeat problem I ordered an entire HVAC case. Part is not in stock and was ordered.
They will have to reschedule another service visit for me when the part arrives. I'm hoping that this can get figured out before summer warm weather is over and it'll be harder for me to verify that it's working properly.
Reactions: XPsionic
pacmanbrodude
Nov 13, 2015
27
25
Baltimore MD
After the fix, I ran another test.
outside temp 67, set to LOW
4:08 - 78
4:10 - 67
4:12 - 61
So, in this test, the cabin dropped to 6 degrees cooler than outside in 4 minutes. In my first test, it did this in 20 minutes. However, the outside temperature differences (and also the sun - it's a cloudy day today) are quite different, so it's not a perfect test. But I'm convinced enough that it's resolved.
Reactions: Nikooo777
Similar threads
