Does auto lane change work for y'all?
pvogel
917
199
Santa Clara, CA
Only time it hasn't worked for me was today when I needed to shift right from slow moving traffic to almost dead stopped traffic. I found a gap that worked for me but the autopilot refused to try it.
FlasherZ
Sig Model S + Sig Model X + Model 3 Resv
Jun 21, 2012
7,024
1,013
I've had it refuse to work when rain kept blowing water across the sensors.
That said, my problem with it was pilot error originally... Creating a new driver profile switches it to off, you must go back and turn it back on.
Reactions: Blastphemy
Blastphemy
641
277
Los Angeles, CA
Mine worked the first day I had the car, then didn't work for the subsequent two drives, then worked again yesterday. No rhyme nor reason, and very little traffic each time.
FlasherZ
Jun 21, 2012
7,024
1,013
I've had situations where it stopped working and I didn't know why. I wish there were some kind of an indicator that told you the reason it wasn't working. In the rain, the only reason was that I caught a glimpse of the side sensors flashing yellow VERY briefly.
loganintx
608
465
Austin, TX
From what I understand, auto lane change will only work when the car is able to detect the outside lane markings of the lane you are trying to change to. You can see this on the dash represented by a grey line. If the car can't detect that there is a land next to yours then regardless of whether there is an opening in traffic, it won't attempt to change lanes.
ShotgunF15E
352
289
San Diego, CA
There is a problem with auto-lane change at the moment. So far this has been the most reliable part of the autopilot package for me. But after the latest firmware update it goes haywire.
The dash indicates that there is a clear lane to change into. So hand on the wheel, set the blinker and now the "clear lane" just disappears from the dash. Nothing else happens, no dashed blue line, no change in speed nothing.
Then sometimes it suddenly works perfectly again. It's almost as if Tesla tweaked the "clear lane" code and it broke in a subtle way.
I tested this on an almost completely empty motorway and it didn't work reliably most of the time. A huge change down from the almost 99% reliability I've had so far.
Note this was in a Model S, but the hardware is the same.
I've noticed the exact same thing with my MS. Not sure what they changed but they managed to break it.
ptsagcy
528
176
NJ
Mine has worked extremely well for the month I have had my X, including a trip from northern NJ to Richmond on auto pilot most of the way. Between the comfortable seats and seating position, and auto pilot, it is the best road trip car I have ever owned.
Reactions: loganintx
Blastphemy
641
277
Los Angeles, CA
That turned out to be my problem too. We created a new profile, but forgot to enable auto lane change on it. Then we didn't pay attention to which profile was active (because we thought they were triggered by which person got into the driver's seat with their fob) and didn't figure out until seeing your post that the profile was the problem.
cantdecide
378
237
Boulder, CO
We've had a few failures...
Auto-lane-changing requires the car to be seeing very clearly... your lane, the next lane, lack of cars around, etcetera.
Even using full indicator we've had it balk partway through a lane change twice... once appears to have been because we went under an overpass and it seems the car lost sight of the other lane momentarily so it reverted to the original lane for a couple of seconds, then changed successfully.
It also seems reluctant to change into newly created lanes.
Zac C
13
18
Westford, MA USA
After almost 2 weeks and over 1,000 miles, I've had auto lane change work for me every time. My son had that problem (human error) where it was switched off in his profile and then wondered why it wouldn't work for him. :)
We tried having it lane change onto an exit ramp - it slowed down and started to take the exit but then I had to take over because it was still going to fast and not turning onto the ramp correctly. Maybe if I had been following a car exiting it would have worked? I'll have to try it again.
FlasherZ
Jun 21, 2012
7,024
1,013
I was in an exit-only lane, following another car, and the car didn't seem to want to follow the exit (despite very good markings). It seemed to want to continue on the roadway and took me to the left side of the exit before I took over. I haven't had time to experiment a bit more, but it seems like there are more forces in play.
ptsagcy
528
176
NJ
Did you leave the turn signal on? Turning it off too soon will abort he lane change.
FlasherZ
Jun 21, 2012
7,024
1,013
Was the lane next to you crowded? I've seen this when there's A LOT of traffic and so the camera cannot clearly see the lines and/or gaps.
Nope, very sparse traffic in the afternoon.
ShotgunF15E
352
289
San Diego, CA
After driving with the autopilot for the last couple weeks, I'm amending my original opinion of the system and now feel very satisfied that it's working exactly as advertised and described in the operator's manual and release notes. Is it perfect, no, but it still works to the best of its ability as designed. I'm sure it will only get better over time as it matures in capability.
EcoHeliGuy
545
127
Canada
This is why Tesla makes you confirm that it's a Beta Software when you enable the feature the first time, and again when updated.
System works extremely well compared to what was available in the market before the Model S included the system.
Glad to hear your enjoying it
JimmyAZ
300
46
United States
Very odd. I would contact your service center and see if they can pull the logs. I know that mine does not require any steering wheel input to start. It does sometimes take a moment to ensure the lane is open for the lane change. But it's consistently able to do it. I rarely move the turn signal to the detent position. I just nudge the signal to activate and hold it until it's about halfway through the change. Best of luck!
pvogel
917
199
Santa Clara, CA
I noticed today driving down 680 that if there's a car passing the front quarter panel of the car in your destination lane when you signal a lane change it doesn't go for it even after that car has passed.
