does battery degradation plateau, or is it more straight-line, or what is the shape of the curve?
syswei
131
15
FL & CT
I have a 70D with 2k miles on it in about 6 weeks. It was getting 211 miles range (at 90%) but is now down to 208. Losing 3 miles isn't a concern, but if degradation continues at anywhere near this rate, I'm definitely concerned about how things will look at 40k or 80k miles.
Reactions: Vince Cobelo
Max*
Charging
Apr 8, 2015
6,670
3,719
NoVa
[at 90% SOC] My 70D started at 214-218, within a few weeks I was around 212-214, then shortly after down to 208-210, and it stabilized at 208. A year later (25k miles driven in that year), I'm still at 208.
TampaRich
420
333
Tampa, FL
At 10K miles I'm hitting 212-214 on a regular basis with my 70D, 52 mile commute, charging every third day. I wanna say that I started at 220 when I took delivery 9 months ago.
TexasEV
7,642
8,470
Austin, TX
Degradation is more in the first year and then slows down to about 1% per year. My 3 year old 60 starred at 208 and is now at 200.
Rifleman
Now owns 2 Model S's!!!
Nov 29, 2011
991
77
Harrison Ohio
You are doing better than my 2014 S60. I am at 187 @ 100%. My wife's 2013 S60 is still at 198 @ 100%. Both of us are around 40k miles.
Petra
813
1,218
Palmdale, CA USA
I picked up my 70D about nine months ago and, at the time, my 100% showed 238 rated miles and 90% was 215 rated miles. 9k miles later and my 90% is still between 213 and 215 miles and 100% still comes up to 238 miles.
ran349
431
279
SoCal
I have a 14 month old 70D with 20k miles and my 90% is around 205. Most of the drop came very early on and for the last 6 months it has barely changed. Hopefully, you will see the same leveling off.
Morristhecat
723
202
Burnaby, BC
I can only speak of my experience, but I found in the 1st 3 months there was quite a bit of degradation in my S60. If I recall correctly I think I started out with about 324km at 100%. After about 3 months it went down to 320km. Now after 3.5 years I can still achieve 320km as long as I balance the pack out about 2 times prior to a 100% charge. I find I only need 100% very rarely though, and I regularly charge to 80% most of the time. I think that the key for long battery life is to only charge to 80%, keep it above 25% on a regular basis. 90% is fine too, as recommended by Tesla, I just side on safety.
Matteo
174
31
EU
Hi,
This is how the curve looks like. You can add your data to the same survey HERE.
Reactions: bkp_duke
