  • The final cut of the 9th episode of the Tesla Motors Club Podcast, featuring Chad Schwitters, the former president of Plug In America, is now available. You can watch it now on YouTube or listen to it on all major podcast networks.
Does button on charging cable open Plaid charging port?
DerbyDave
2,303
1,350
Kentucky
It should open the door. Is this a new wall connector? Did it ever open the door? Have you set up the wall connector and its WiFi connections? When you connect to the wall connector is it showing any errors? Tesla can do remote diagnoses and repair/replace if necessary. Get the identifying information for the wall connector and call Home Charging Support team at 877-961-7652 and select the option for wall connector. The team is available M-F 8 AM to 5 PM PST.
Reactions: Rocky_H
It's a bug. My August '21 Plaid charging door will open on some chargers but not all. Can't yet determine a pattern, no matter the charging source.
Tried moving the connectors various places around the port while pushing the button.
Sometimes it works, sometimes it doesn't. Again, no discernible pattern.
(best guess: 35 different charging sources in 11(?) states - level I, II, SC, whatever)
Since I am 2 inches from the port anyway, if the button doesn't open the port, I just touch it to open.
For me, this is a minor nit (is that redundant?) - certainly not worthy of me taking it in for a fix or calling out a Ranger.
Should it work all the time? Of course it should. But it doesn't. Of course it's a defect, but I can ignore this one. Entertaining in a way.
If the fix involves disassembling the car for a new antenna or such - no thank you - the work-around is less hassle than the repair.
If the fix is software - no problem. Do it.
Curious about the fix if there is one. Anybody have more info?
Reactions: oktane and Rocky_H
WilliamG
Hinge Fanatic
Apr 20, 2019
5,763
9,297
Seattle, WA
It's not a bug. It's a broken antenna in the charge port. You'll find if you open the trunk and point inside it it'll work fine. I had mine finally replaced. The part number is:
HV INLET,ASY,NA INTERIM,SX,P2(1567500-70-B)
This is a common issue. Don't kid yourself it's software.
See this thread:
https://teslamotorsclub.com/tmc/threads/can’t-open-charge-port-with-wall-charger.249584/
oktane
2,047
2,973
I have an original wall connector wired to a 100A breaker I believe, and pull 80A on a charge (60 mph on dual charger equipped cars). No idea if there is WiFi on this thing, I really don't think so.
Reactions: DerbyDave
oktane
2,047
2,973
See this thread:
OMG. I'm going to try from inside the trunk and see if it works. It sounds like a common issue, very poor quality control on this part it would seem.
Reactions: WilliamG
oktane
2,047
2,973
See this thread:
You were spot on. My charging cable opens the port when I aim from inside the trunk, but not from outside the car.
WilliamG
Hinge Fanatic
Apr 20, 2019
5,763
9,297
Seattle, WA
The charge port is located on the left side of Model S, behind a door that is part of the rear tail light assembly. ... If the charge cable is close to the charge port door, you can press the button on the charge cable to open the charge port door even when Model S is locked or a recognized key is not within range
What on earth? :D
Reactions: Neon001
Neon001
306
693
Md
Yeah I have this issue as well on my LR. It works sometimes, but often I'll have to get close enough that the (very small) door will actually strike the charging cable as it opens, and I don't want to damage the mechanism. So, I just press on the charge port. Maybe I'll get around to having it fixed, but after numerous other day-1 issues, I just want to get the important stuff resolved and drive the damn thing for a while.
