Does dashcam drain the battery?
Discussion in 'Model S' started by jbonne84, Nov 8, 2016.
Tags:
  1. jbonne84
    jbonne84 New Member
    vancouver
    I'm looking at installing a 2 channel dashcam and preferably have it run 24/7 to record in case somebody keys the car or dents the doors. Since the car is essentially just a big battery anyway, should I be concerned about it running 24/7 on such a power draw?
  2. mblakele
    mblakele pre-jackpot member
    SF Bay Area
    I haven't noticed a significant draw. Mine is supposed to use about 5 W for front and back combined. I figure it would take two or three days to consume a single range mile.
  3. f-stop
    f-stop Active Member
    Vancouver BC, Canada
    I wouldn't worry about it. As an example the Blackvue DR650GW-2CH (which many of us here have) draws a maximum of 4.8 Watts when recording - so 400mA max - almost negligible in the grand scheme of things. It has a parking mode which is quite sensitive to motion and records almost continuously in a busy parking lot or street, but if parked overnight in a dark garage it's not actually recording continuously anyhow.
  4. Model S M.D.
    Model S M.D. Ludicrous Radiologist
    Houston, TX
    Mine is tapped into my 12V and I haven't noticed anything of significance. It is well worth it.
  5. Barry
    Barry Active Member
    Colorado
    I notice an extra 1-2 miles/day of vampire drain since installing my Blackvue.
  6. cynix
    cynix Member
    Sydney, Australia
    I have a Thinkware F750 recording 24/7 and didn't notice any significant impact on drain.
    The real problem is I can't find a SD card large enough to store a whole day's recording! I'm using a 200GB card now and it's only enough for about 9 hours of video.
  7. Barry
    Barry Active Member
    Colorado
    Can you cut back on resolution or the frames per second?
    I cut my Blackvue down from 30 fps to 15 fps and don't notice any significant difference.
  8. Model S M.D.
    Houston, TX
    You record more than 9 hours in a day? Try cutting back on the sensitivity settings. You should only be recording while driving and when there's an impact/motion detected in parking mode.
  9. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    Mine caught Bambi
    I actually had NO idea what happened when it did until I watched the video.
  10. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
  11. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
  12. cynix
    cynix Member
    Sydney, Australia
    I set it to continuously record.
    Thinkware F750 doesn't have GPS-based "parking mode" so it can't tell if I'm driving or not.
  13. NeverFollow
    NeverFollow Active Member
    Is it at 0:24 on the left?
  14. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I have had no problem with my Blackvue 650 dual cam. But I keep my car plugged in every night.
