Does everyone have trouble opening their charge port door?
Discussion in 'Model S: Battery & Charging' started by Lerxt, Jul 31, 2015.
  1. Lerxt
    Lerxt Member
    Hong Kong/Australia
    Was at a supercharger today and when I turned up I had the usual 5 minute wait to unlock my charge port door. While I was waiting 2 others turned up and both couldn't open their charge port door as well. This thing should work the instant the open button is pressed.
  2. siucity
    siucity Button Pusher
    SF North Bay, CA
    Sorry to hear you're having trouble with it, but I've never had any issues with mine. It opens right after I push the button, whether I'm at home or at a supercharger.
  3. Matias
    Matias Active Member
    Finland
    I have read of some problems with glue oozing to magnet.
  4. saladman
    saladman Member
    Seattle, WA
    Had this problem yesterday with my home charger. I pushed button nothing happened. Pressed again multiple times, nothing. Stood there for a minute, staring at the charger, the car, trying to think of next logical steps, suddenly charge door opened.
    It was like the computer was locked up, had to finish some process, then got to its backlog of tasks...
  5. trils0n
    trils0n 2013 P85
    SF Bay Area
    I've never had any problems with the door opening. I have been to a supercharger where the button on the cable didn't work, so I had to open the charge port from the touchscreen.
  6. scaesare
    scaesare Well-Known Member
    NoVA
    No. Weird.
    Do you hear the click as if the computer is unlocking it, and it doesn't correctly open for some reason, or does everybody seem to be saladman's experience where it seems that the computer isn't sending the unlock command?
    Knowing if these are the old-style open-only ports or the new fully actuated self-closing ports might be interesting too. FW revision is probably useful as well.
  7. Rockster
    Rockster Active Member
    McKinney, TX
    Mine has started doing this recently. I haven't done any controlled experiments but I think it's happening only at home and not at any Superchargers. This suggests that my problem might be my HPWC wand's transmitter. I'm going to break out my mobile charger this weekend and do some side by side comparison to see if it's my HPWC or my car. I'm not hearing any kind of "click," which I interpret to mean that my particular problem is not a stuck magnet or door. When the failure to open occurs, the port seems like it's not even trying to open.
  8. Forty Creek
    Forty Creek Member
    Carlisle, Ontario
    In that situation, I wonder if it would respond to the FOB any better?
  9. demundus
    demundus Active Member
    Oceanside, CA
    Without asking them to, when I went in for my warranty motor work, my charge port door assy was completely replaced. Someone must have seen something I didnt. From the invoice:
  10. steph280
    steph280 Member
    Orange, CA
    the newer self closing door can be opened just by pushing on the door itself.
  11. jcaspar
    jcaspar Member
    Sacramento
    Never had mine even hesitate to not open instantly.
  12. Electric700
    Electric700 Active Member
    Florida, United States
    I had this problem recently and was able to get around it by gently pulling on the charge port door while simultaneously pressing the button to open it. The problem fortunately hasn't happened since.
    An alternate method might be to push on the hinge side of the door while simultaneously pressing the button on the charge connector or pressing and holding the trunk button on the key.
    Hope this helps!
  13. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    I had trouble with an older cable on my HPWC where it would take several presses and often holding the handle over the rear glass near the sensor to get it to open. Tesla replaced my cable and for a couple of weeks it worked amazingly well. But over the past few months it seems like things are going back to their old habits and it takes a few presses.
    That said, I don't know why you'd wait 5 minutes, just use the control panel on the touch screen to open the door if the button on the charger handle isn't working.
  14. mwulff
    mwulff Member
    Danmark
    My car has had intermittent problems opening the chargeport door. There isn't any rhyme and reason to it though. But I have seen it on two other danish cars so far.
    There seems to be a problem with the EU chargeports.
  15. mknox
    mknox Well-Known Member
    Toronto, ON
    Me neither... except in the winter when it sometimes freezes. I just use a credit card to "help" it open as I push the button when it's iced up. But the release happens the instant I hit the button.
  16. CatB
    CatB Member
    Alexandria, VA
    I just had this problem on Wednesday. Panicked a bit and went back to the touchscreen to unlock/open a few times, finally worked when I closed the driver door. Last night was fine.
  17. m6bigdog
    m6bigdog Member
    San Ramon, CA
    Yep!
    About half the time the port opens when commanded from the cable, the other half you need to manually open the charge port door.
    When it works it seems to function normally for a number of times before it quits and you manually open the door.
  18. jbcarioca
    jbcarioca Well-Known Member
    From time to time it seems to affect amost all of us, I think. It has never been an unsurmountable problem for me, but is a nagging issue. I ignore it, basically.
  19. evp
    evp Nerd
    Arvada, CO
    I had this problem two days after I got the car. In the rain, at night, at my first supercharger on my first road-trip. The car was clearly getting the signal, I could hear the lock clicking.
    Tesla support suggested that I press on the far-rear side of the charging door, past the hinge point, as I push the charger button. Aster a few tries, that worked. (They also suggested I could wedge something thin in and pry it open after the click.)
    After I got back to town, they did a mechanical adjustment and I haven't had the problem again.
  20. jepicken
    jepicken VIN: 80322
    Chandler, AZ
    My charge port door rarely opens on command, even though I can clearly hear a click indicating that it's trying to open. The first time it happened was at home, and I just waited a couple hours and tried again, and it worked fine. When it happened again just before a road trip, I called Tesla, and they gave me a workaround - hit the back edge of the charge port door with the bottom of your fist repeatedly and with increasing force. That works well enough to get the door open. Tesla told me to clean the magnets, since this is usually caused by some sticky gunk getting on there, but cleaning it didn't fix the problem for me, and there is no gunk whatsoever. This has been happening now for about 3 months, on a 4 month old car. Eventually I'll take it in for service to fix it, but so far I'm getting by with the workaround so it isn't a top priority.
