Does GPS Know (Ask?) if there is Destination Charging?
Discussion in 'Model X: Battery & Charging' started by Birdman325, Sep 1, 2017.
  1. Birdman325
    Birdman325 Member
    Toronto, Canada
    This might be clear when I actually get a Tesla and try it out, but let's assume that I am driving somewhere from my home in Toronto on a day trip. I put in the address of my destination, and I understand that the GPS will advise me whether or not I need to charge / stop at a SC in order to reach my destination. (Is that correct?)
    But let's assume that my destination does not have any charging availability and I want to drive home the same day. While I may have enough charge to get to my destination without charging, how will I know (or the GPS) whether I will have enough charge to turn around and not necessarily make it home, but maybe make it to a SC somewhere on the way back.
    Is there a "round trip" option when you plug in the coordinates?
  2. jareade
    jareade Supporting Member
    Driving
    Yes, when you plug in your coordinates, it will show what your battery percentage would be if you made a round trip (often negative if it's a long trip). So it should show exactly what you are looking for.
  3. aesculus
    aesculus Still Trying to Figure this All Out
    Northern California
    From the manual
  4. Birdman325
    Birdman325 Member
    Toronto, Canada
    Fantastic. Thx.
  5. BerTX
    BerTX Active Member
    Texas/Washington
    One still needs to assess the route plotted to see if it makes sense. The system is far from infallible and does stupid things sometimes. It often also routes to Superchargers when it isn't necessary, or routes to SCs that are not the best way to go.
  6. Racerx22b
    Racerx22b @unplggdd on Instagram
    West Palm Beach, FL
    And if you stop on your trip or cancel GPS guidance when you start it again it'll assume your return point is the point at which you started guidance. Not your home.
