Does making too many token requests get you throttled?
Discussion in 'Model S: User Interface' started by wayner, Dec 28, 2016.
  1. wayner
    wayner Active Member
    Toronto
    I am doing some playing around and I am no unable to get a token. My process uses teslajson.py that requests a new token every time you use it. Is this a way of getting locked out? Should I just cache a token an reuse it until it stops working?
  2. Drewflux
    Drewflux Member
    Australia
    Short answer is yes. its happened to other members in the model s rest API thread.
  3. tliving
    tliving Member
    New England, USA
    Teslajson didn't used to let you provide the token back to it, so I forked it and added the feature and the owner merged it back in. That was back in Feb 2016. Unfortunately the original author just made a change (1.2) that broke that feature -- you can't get the token back any more.
    That broke a bunch of my stuff, so I reported it and resorted to going back to using my fork:
    GitHub - the-mace/teslajson: Simple Python class to access the Tesla JSON API
    With that fork you can get the access_token from the Connection object and keep it around for however long you want. This is how EVTripping.com connects to Tesla owner's accounts only once and then only keeps the token (not any passwords) for long term monitoring.
  4. cryptyk
    cryptyk Member
    United States
    I used to run EvMote. I had a few thousand teslas using the site and lots of testing before it went public. I never saw any intentional throttling from the tesla APIs even with thousands of concurrent GPS stream connections and hundreds of concurrent API requests. I also did lots of messing around with the APIs while I was developing and I'm sure I requested oauth tokens a few hundred times per hour in the early days.
    I'm sure they will throttle you if you're abusive, but the threshold appears to be pretty high...
  5. cytranic
    cytranic Member
    FL
    Yes, when I was testing, especially when making bad calls they would rate limit me... Normally for a few hours, but i've seen 24 hours as well.
