Does my Model S (December/2013) have the wiring for a dashcam?
Discussion in 'Model S: Interior & Exterior' started by cyr0nk0r, Jul 20, 2018.
  1. cyr0nk0r
    cyr0nk0r Member
    Phoenix, AZ
    I am curious if my Model S, manufacturers in December 2013 has the 'constant' always on wiring above the headliner for a dash-cam?
    I am interested in getting the newly released BlackVue DR900S-2H, and am wondering if my car has the wiring that is needed to support that system rather than needing the extra battery pack stuff.
    Also, if there are any good recommendations for installers in the Phoenix, AZ area I would appreciate anyone giving me their experience. Thank you!
  2. P85_DA
    P85_DA Supporting Member
  3. cyr0nk0r
    cyr0nk0r Member
    Phoenix, AZ
    Yes, I've read that. That is why I'm asking if December 2013 cars have the 4-pin, 3 wire connector for always on power. That article mentions some cars in late 2013 to early 2014 might not have it so I'm asking if anyone else who might have December 2013 cars can assist with confirming if that connector is there.
    And if not, who might be a good installer that knows how to connect the dashcam so there is no wiring showing and knows how to wire these cameras up in Tesla's.
  4. darrelld
    darrelld Member
    North Texas
  5. cyr0nk0r
    cyr0nk0r Member
    Phoenix, AZ
    @darrelld, so with that wiring harness, you did not need to use either the power magic battery pack, the power magic pro, OR the power magic ultra battery?
    If so, how does the BlackVue connect directly to that harness you linked to?
  6. P85_DA
  7. cyr0nk0r
    cyr0nk0r Member
    Phoenix, AZ
    Also, if I don't want the dash cam recording 24x7 (just when the car is running) do I need this always on wire in the headliner?
    What is the wiring recommendation if I only want it recording while the vehicle is on?
  8. darrelld
    darrelld Member
    North Texas
    I just cut the wires on the other side of the OBD fuse and hardwired the Blackvue to that use butt splices. Ran the Blackvue wires behind headliner and along A pillar on the drivers side to ODB adapter right above the dead pedal.
    No power magic used in my case but you could use it to limit the run time on the camera.
  9. P85_DA
    The BlackVue has a parking mode ...r u saying u don’t want recording than ? Only when driving ? The only reason to go thru this wiring effort is to allow to run in parking mode and for cleaner install ..if u just want to record when driving just plug into 12v in console
  10. JPP
    JPP Active Member
    SF Bay Area, CA
    How about simply pulling down the mike grille in the headliner (pull from the side that faces you, not the windshield)? It will swivel down. Look on the back side for a flat connector taped there, or maybe tucked under the headliner. Get out a test meter and check it. You need 2 pins that give 12V (one is likely going to give a lower voltage).
  11. P-town_P85
    P-town_P85 Member
    Pleasanton, CA
    Not all S have that. There was a window starting in late 2013 where that extra connector isn’t there. Guess where in that window my car is.
  12. cyr0nk0r
    cyr0nk0r Member
    Phoenix, AZ
    I want the 'cleaner install' part of that statement. I don't want wires hanging down from my windshield. You are correct though, I only want to record while the car is on. I DO want it to record when in park. Just not when the car is 'off'
  13. P85_DA
    Ok probably some semantics ..the car does “sleep” ...but in park mode (camera) will still record provided it has power ...the only way to turn cam off is physically unplug power from cam ...
  14. darrelld
    darrelld Member
    North Texas
    My 2014 Model S OBD plug is always powered on and my Blackvue runs 24hrs, park mode enabled with no flashing lights or wifi lights when not in motion.
    The advantage of running this way is clearly shown in this video.
    I have not noticed any extra battery drain and power consumption is minimal with the Blackvue 750 2CH.
    15 Things the DR750S Series Dashcam Does Better - BlackVue
