I haven't researched this, I thought perhaps someone already knows the answer.
We know that in off-grid mode, PW2 can raise the frequency high enough to shut off all PV production when the batteries are approaching full and PV production exceeds demand. I think I read a post recently that it can first do smaller incremental frequency increases to attempt to curtail production rather than just shut it all down. Is that the default behavior or does it require some configuration on the PW2 end? Obviously whether the PV inverters support curtailment that way is a separate question.
On the load side, if the microgrid demand exceeds the available supply (PW2 inverters plus any PV production), ultimately the PW2 will shut down. But it has some surge capacity, so it may not need to shut down immediately. Does it drop the frequency below 60 Hz (perhaps incrementally) when the required power production exceeds its continuous rating and it has to start into its surge capacity?
I recently learned that there are commercially available load shed devices that are designed to trigger solely off AC frequency and can disconnect loads when the frequency drops below 60 Hz. So I'm wondering if they might be compatible with PW2.
Cheers, Wayne
Cheers, Wayne
