I didn't order my car with the "High Power Home Charging" kit as the way its advertised, it only comes across as being beneficial in the home. In other words, they fit your home with something that allows you to charge faster in the home. I assumed my car would still charge at 80A outside of the home (e.g., at an HPWC). I'm sure that many of you picked this up, but it didn't come across to me. Especially since I live in an apartment-like complex, I skipped over it quickly. Little did I know this would limit me to 40A outside the home also
All of that said... it's $2,700 if you get it installed with your car these days. The way it is worded, it seems as though your car is fitted with the dual charger (internally), and then they give you a HPWC to install in your home. Is that correct? In terms of retrofitting, there is a "Dual Charger with Installation" on the accessories website. This clearly replaces your internal single charger with a dual charger. My question is whether the $3,600 retrofit also comes with the HPWC or is that also an additional charge?
I really wish they would not word dual charging as "High Power Home Charging" as it has an effect outside of the home.
Thanks!
Thanks!
