I picked up a 2023 Model 3 RWD LFP and I've already put about 3k miles on it. Does the car notify you when maintenance is required like having a maintenance light like in a ICE car?
No, it does not.
Teslas are not as smart as BMWs or Mercedes.
I saw the owners manual recommends bringing it in at 6,250 miles for a tire rotation so that is the only thing I am keeping a look out for manually
You can track tire wear yourself (with a penny, or
one of these inexpensive tools), and rotate wheels front<->back yourself when the tread depth starts varying by more than 2/32nds. Personally, I do that twice a year when I switch between summer and winter sets of wheels+ tires.
Its FAR easier to DIY wheels rotation in your driveways (30 minutes all around, not counting beer brakes), then scheduling services anywhere.
Time savings are priceless!
As far as tire rotations and new tires goes, is it best to schedule service with Tesla? I did all the tire maintenance with my last car at Discount Tire and I saw they also have a webpage about Tesla tires. Is Discount Tire a good place to get a Tesla serviced?
Use the same places you used for suspension and tire + wheel maintenance as you did with your prior cars.
Discount Tire will work great.
Dealer service centers, including Tesla's, are just about the most expensive and the least experienced places you can find for wheel and suspension work. Around here, appointments with a Tesla SC is a 4+ weeks out scheduling gauntlet. Don't run it, unless absolutely necessary.
Do I need to buy the pucks to lift the car if I do bring the vehicle to a 3rd party shop?
Absolutely unnecessary. If it was, Tesla would be selling them to you directly!
Although, there is a significant volume of fear mongering on that subject by those who are selling those aftermarket scam artists.
I look at it this way:
- No car is designed to be lifted at random places. Every car shop that lifts cars, knows how to place a jack / lift point under the easily identifiable lifting points.
- If you found an idiot who doesn't know how to find a jacking point under a car, they certainly will not figure out how to use the pucks anyway ;-).
I would assume Tesla would charge a lot more for maintenance similar to a dealership.
[...]any other maintenance suggestions to keep the car lasting for a long time?
Yes, Tesla out-of-warranty labor rates are obnoxiously above regular regional dealer service labor rates.
The larger challenge is that Tesla significantly under-specifies the required maintenance to later claim that their cars are cheaper to maintain. It's a bit of a scam.
For example, all brake fluids are hygroscopic, and need to be flushed every 2-3 years. That's physics. It also costs money.
Tesla declares that physics don't apply to its brake fluid, and you don't need to flush old fluid out. That saves money in the short term, and will earn your a brake caliper rebuild and ABS pump swap in the longer term, by which point you will be out of warranty.
Other regular maintenance items:
- Brake fluid flush - every 2 years (every year if you track your car). Clean calipers and guide pins while you are there.
- Cabin-air (HVAC) filter replacement every 1-2 years. Varies by climate. If you start getting musky smell when you turn AC on/off, it's time. Spray Lysol into the air intakes to kill off the bacteria while you are there.
- 12V battery - every 4-6 years, as you would with any other car. Varies by climate.
- Coolant system flush- every 3-4 years, as you would with any other car.
- Minor things:
- wipers every year, or 2x / year, or as needed on your climate and the amount of driving that you do in heavy winter ice and slush.
- change wiper fluid seasonally (if you ambient temps drop below freezing)
- wax and polish the paint thoroughly at least annually, or more often if you want the car to look great.
HTH,
a
