Does the Factory Apply a Fresh Coat of Wax re: Liquid Glass
Discussion in 'Model S: Interior & Exterior' started by SDRick, Jul 31, 2016.
  1. SDRick
    SDRick Member
    SD CA United States
    I plan on applying a coat or two of Liquid Glass to my new model S. Directions recommend removing any existing wax. Does anyone know if the car comes from the factory with a coat of wax?
  2. STbreaker
    STbreaker Member
    Long Island, NY
    Traditional wisdom says you shouldn't really wax until paint cures, so I doubt it comes with anything. My car came clean but didn't seem waxed at all.
  3. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I have never seen anything about new Teslas being waxed before delivery to the owner. Normally one does not wax new paint.
  4. cman8
    cman8 Member
    United States
    From my understanding they paint seal it before delivery is done. I asked mine not to be sealed or waxed before delivery as its done where your taking delivery of it.
  5. BertL
    BertL Active Member
    Carlsbad, CA
    OP, my suggestion is it does not matter what Tesla may or may not apply over the fresh paint -- even at the SC, as you are going to want to do the same amount of prep before applying a coating one way or the other.
    I agree that Tesla likely does not standardly apply anything at the factory, but if I were you, tell your Delivery Specialist you don't want any exterior prep done on your MS other than perhaps a wash before delivery (that's what I did). I used Dawn to wash my MS once I got it home (just that one time to remove any wax or non-semi-permanent polish applied at some point), then used IronX to remove any "rail dust", followed by a clay bar to ensure there were no other contaminants on the paint, glass and chrome, then washed again before inspection and determination if any correction was necessary before I applied my polish or coating of choice. I suspect you may want to do the same to ensure you have a "perfect" finish before applying your coating. Good luck.
  6. SDRick
    SDRick Member
    SD CA United States
    Thanks for the comments. I did also confirm with Tesla that wax is not applied at the factory. Which makes sense now that I think about it and reading the words of wisdom above.
