Does the Model S have an OBD-II connector?
17.088
The North Star State
First, an acknowledgment: Yes, I do very much know that the topic is the ODB-II __in_the_Model_S__.
I'm very, very far down the waiting list (early October, 2016) for a Tesla 3.
I'm also a customer of T-Mobile.
I recently read an interesting web-article at this URL:
T-Mobile SyncUp Drive can create a Wi-Fi hotspot in your car and analyze vehicle diagnostics
It sounds intriguing to me, for both the here and now as well as the future.
So, here comes the obvious questions:
1) Does anyone know if the Model 4 will include an ODB-II connector?
and
2) Will it be located in an unobtrusive location, such that the above mentioned "T-Mobile SyncUp Drive" can be plugged in, and NOT in the way when someone is driving?
DOCAL
459
804
San Jose, CA
and
By law it's required to have one, and I believe it must be within a certain distance from the steering wheel. Beyond that I won't speculate.
garygid
620
114
Laguna Hills, Orange County, CA
Having the standard OBD CONNECTOR does not mean any specific device will work. Here's why:
Most of the OBD "dongle" devices expect to be plugged into a vehicle which has the emissions-mandated OBD-II signals, pin usage, and command/response structure. The device then communicates, often via bluetooth, but sometimes as a WiFi access point, to an app on a smartphone or tablet, or a program on a laptop or similar computer. After connecting to the OBD dongle, the app/program usually asks the dongle to obtain, query-and-read, or listen for specific useful data. Some of these work fairly well on typical later-model smog-producers, including most hybrids.
However, an all-electric vehicle produces no emissions, so it, like the Tesla R, S, X, and model 3, is exempt from the OBD-II requirements. The EV manufacturers have mostly chosen to avoid supporting the OBD-II commands and data structure, and most have produced their own proprietary interface, even though the vehicle has the standard 16-pin OBD connector.
Thus, the bad news is ... the device that you read about, unless specifically designed to include support for your specific EV, is probably useless on your EV.
The good news is ... our clever group has created TM-Spy for the Tesla, and Leaf-Spy for the Nissan LEAF, with apps for both Android and for later iOS devices. Compatible ELM-type OBD dongles are supported, with Bluetooth, Low Energy BT, or even WiFi interfaces. The link in my signature line will help you find more information about TM-Spy, fairly efficiently.
Cheers, Gary
busaman
237
93
suffolk UK
I was at the Rockville Service Center today and asked hem about it. I was told that the car has an OBDII connector because it is required by law. However, I was told that it does nothing; that the only pins connected to the connector are ground and voltage.
looking at the picture pins 6,7 and 14 are populated also which would indicate can-bus comms 4&5 are gorund 16 +12v.
mknox
10,103
1,866
Toronto, ON
Can anyone confirm/deny if very early Model S cars even have an OBD-II port? I'm talking Sigs and early production models. I heard they didn't and added it later to comply with some regulatory request. I've looked all over my 6xxx-VIN car and can't seem to find it.
artsci
Sponsor
May 10, 2012
6,247
3,217
Timonium, Maryland
From what I gather the OBDII is just there for regulatory purposes, and a minimum of information is put out to it. And there are other Tesla plugs where they really interface with the car's software.
The port puts out no information of any kind, although it is a good source for an always on 12v power supply.
Reactions: KArnold
tliving
751
102
New England, USA
I believe they all did. My Early 2014 S85 has one (I use it for constant 12V)
tliving
751
102
New England, USA
On a LHD car, it's above the foot rest for your left foot:
mknox
10,103
1,866
Toronto, ON
Damn, you're right. I just went out and checked. I had been looking all over the area around steering wheel shaft where it has been on my previous ICE cars. Guess I didn't twist my head around enough to see it facing straight down. Thanks!
jstack6
76
22
Sunny Chandler Arizona
My 2012 model S 85 has an OBDII. I use it to get lost of great trips data for a FleetCarma study. It works fine.
markwj
Moderator, Asia Pacific
Apr 10, 2011
4,583
1,179
Hong Kong
I thought FleetCarma used an adaptor cable to get the data from the DIAG connector (under the cubbyhole)? That was the original plan.
mknox
10,103
1,866
Toronto, ON
It does. I have one. The device is an OBD II plug, but for Tesla comes with a short cable that has a Tesla plug on one end and an OBD II socket on the other. You plug the device into the adapter cable and the cable into the Tesla Diagnostic connector behind the center cubby.
markwj
Apr 10, 2011
4,583
1,179
Hong Kong
Thanks - that's what I thought. Data comes from the Diagnostic connector (not OBDII port).
BearBu
411
437
Hong Kong
Is there any pic of the device can be shared? Or any link that I can purchase?
Thanks
markwj
Apr 10, 2011
4,583
1,179
Hong Kong
I have a P85+ made in 11 of 2013. I do not have a diag port under my screen.
Any ideas where it might be located?
It will be there. Old style diagnostic connector. The cable comes down from the MCU, so maybe tucked away high. Normally you can see it either behind the cubby (pull it out), or one of the side panels.
Fattchris
29
Heber City, UT
It's not. At least it's it is, out isn't accessible under the screen just by removing the cubby.
I've taken it completely off at the point and there's no cable there at all.
