Does the UMC fit in the wall charger replacement organizer?
Discussion in 'Model S: Battery & Charging' started by Jeff P, Jul 28, 2015.
  1. Jeff P
    Jeff P Member
    Orlando, FL
  2. linkster
    linkster Active Member
    USAX2
    yes
  3. iCAR
    iCAR Member
    Park City, UT
  4. jvonbokel
    jvonbokel John VonBokel
    Belleville (St Louis)
    That looks pretty nice! Can you show more pictures, or explain what that black part is above the receptacle?
  5. Rocky_H
    Rocky_H Well-Known Member
    Boise, ID
    Well, yes but.... I have one of those on my wall for my UMC, but when the cable is coiled around it some, then the handle isn’t always hanging precisely straight down. If there is a little angle to it, it will slip right off that tab in there and fall down. Mine did that a couple of times, and I couldn’t get it to stay in there, so I didn’t want it falling out of there and smacking against my motorcycle, so I leave it hanging over the top.
  6. FlasherZ
  7. iCAR
    iCAR Member
    Park City, UT
    The 240v receptacle is a surface mount 14-50 receptacle from Lowe's, approx $15. The tread aluminum sheet is also from Lowe's, but pricey!
  8. linkster
    USAX2
    #8 linkster, Jul 28, 2015
    Totally agree. I only use it to loop the the cord but not to hook/strain the Tesla connector end.
    iCAR's install looks SUPER clean (LOVE the diamond plate and may have to steal this approach lol)!!! (it's just a little too tightly wound for me, but I am paranoid about charging weather it's my 14-30 or HPWC)
  9. Blue_Model_S
    Blue_Model_S Member
    Silicon Valley
    #9 Blue_Model_S, Jul 28, 2015
    If you don't make the loops so small, it will stay there just fine. With larger loops, for me, it also can be plugged into the car in one motion without uncoiling any loop.
  10. Rocky_H
    Boise, ID
    I know you are trying to help, but I am desperately holding back my sarcasm. Yes, I already tried several sizes of loops and orientations, and it wouldn't quite hang straight enough to reliably stay on there.
  11. ken830
    ken830 Model S 85, Model 3 Performance
    San Carlos, CA
    I do only one or two large loops and I'm also not confident of the connector staying. It's virtually impossible to have enough cable hanging to ensure a straight vertical angle on the connector.
  12. SW2Fiddler
    SW2Fiddler We Are Cognitive Dissidents
    Houston TX
    #12 SW2Fiddler, Jul 29, 2015
    I played with the cool hanger when I finally got my HPWC mounted. I'm geeky like that.
    Ultimately it's just the angle of entry that counts. More parallel to the plane of the wall = mo better.
    If I tucked the *last loop* thru the loophole, behind the other loops, sure enough the cable was flat-against-the-wall enough to be angled to hold in the clip.
    ...After two days of doing this, I started just laying the nozzle across the top of the loop-holder along with the other loops. I guess I'm not THAT geeky.
  13. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    Instead of mounting it directly on the wall, could you mount it perpendicular (perhaps on a small bracket)? That way the holder socket would always be in the same plane as the charging cable.
  14. Blue_Model_S
    Blue_Model_S Member
    Silicon Valley
    #14 Blue_Model_S, Jul 29, 2015
    I am not sure if there is a difference among the UMCs or the organizer, but mine seems very stable with longer loops.
  15. FlasherZ
    My connector tends to fall out a lot when the kids put it in there, small or large loops. I've been considering modifying it with a small wedge block beneath it to pull the bottom out from the wall a bit more.
  16. Nevek
    Nevek Overt Member
    Seattle
    Yep, I also gave up on the finicky hook and just leave it looped. NBD, other than I always appreciate good design and this isn't it.
  17. Andyw2100
    Andyw2100 Well-Known Member
    Ithaca, NY
    I have two HPWCs.
    One of the electricians that installed one of them added a simple wooden bracket, made with some scrap wood, while the other electrician was cleaning up.
    But at my other location I installed one of these to hold the cable, and I just dangle the end over the coiled cable. It seems safer that way.
    Tornado 40 lb. Small Black Steel U-Hook-48004 - The Home Depot
    To the OP: the cost of the above is less than a fifth the cost of the Tesla bracket, and I think you'll find it will hold the cable much more easily.
  18. SW2Fiddler
    Houston TX
    I like the Wedge idea FlasherZ is pondering. But the company could perhaps change the angle of the "hole" too for increased grab.
    This is an opportunity for someone with a 3D printer to produce 20-degree wedge adapterz for existing brackets.
  19. Jeff P
    Jeff P Member
    Orlando, FL
    Honestly, $25 is not really a cost concern considering the check I need to write for the car. :)
  20. Andyw2100
    Ithaca, NY
    I understand.
    I just honestly think the $5 option from Home Depot is actually a lot more functional.
    I received your $25 option free, (included with my HPWC), and am not using it, as there isn't really enough space to coil the cable well.
    I was just trying to provide another option. Good luck with whatever you decide to do.
