I recall someone mentioning the displayed range now takes tire size into account. Is this accurate?
It should. That's why your car has to restart every time you go change the wheel type.
I should say that it affects estimated range. That number next to your battery is a math equation from the EPA number and the battery Kwh and that shouldn't change from changing the wheel.
Interesting... I obviously didn’t go for a drive between swapping.I have 18” Aeros. If I set it to 20”ers I get about 3 miles more displayed consistently. Which is backwards to me. It does NOT immediately change I've got to go for a drive and charge it.
Possibly the Model Y is different than the Model 3 on how it adjusts the displayed range with wheel configuration. My Performance Model Y originally displayed a calculated max range (fully charged) of around 280 mi with the stock 21” Uberturbine wheels, consistent with the EPA range estimate of this car at that time. After I swapped out the 21” Uberturbine wheels with 20” third-party wheels, I had the Tesla service center update my wheel size to the 20” wheels. My displayed range went up to around 300 miles. (The user cannot yet update wheel size on Model Y.) The 300 mi range was also consistent with the EPA range estimate for the Long Range Model Y with stock 20” Induction wheels. Unfortunately, I didn't take a screenshot of the display showing the new 300 mi range at full charge.As stated above, the wheel choice does not affect the displayed range.
Interesting. My Long Range Model Y is on order and I'm struggling between the 20" and 19" wheels. I like the look of the 20s, but range is most important to me. What was your difference in range estimate between the 21s and 20s? The website shows no difference in range between 19s and 20s on the non-performance model, but I find that hard to believe.Yes, if the wheel size is changed in the onboard computer, it will affect the max range that the car will display when it’s fully charged. However, the displayed max range does not necessarily reflect the true max range of the car. I have a Performance Model Y with 21” Uberturbine wheels. I swapped out the 21” stock wheels with 20” TSportline TSS wheels and had the Tesla service center update the computer to reflect the new 20” wheels. My max range increased to the range corresponding to the stock Model Y 20” Induction wheels even though my 20” TSS wheels may not provide that range (not as aerodynamic). I believe with the Model 3 (unlike the Model Y), the user can change the wheel size in the computer.
Unfortunately, I didn't have the 21" wheels on long enough to do a range comparison against the 20" wheels. Also, my 20" TSportline TSS wheels may not be a good comparison with the stock 20" Induction wheels. I think mine are less aerodynamic.Interesting. My Long Range Model Y is on order and I'm struggling between the 20" and 19" wheels. I like the look of the 20s, but range is most important to me. What was your difference in range estimate between the 21s and 20s? The website shows no difference in range between 19s and 20s on the non-performance model, but I find that hard to believe.
So what would be the factors between the 18", 19" and 20" wheels that would affect range? I understand the weight could affect the range but that will likely be inconsistent. All wheels have varying weights regardless of diameter (cast, flow forged, forged, etc.) and so do tires, depending on what width and brand are being used. But how would Tesla's software know any of that information. I would think that outside tire diameter would have more of an effect on the range but there is no input for that information. Doesn't Tesla's 18", 19" and 20" tire packages have the same outside diameter?
Yes, it adjusts speed settings in the computer to match the tire's outer circumference, assuming Tesla stock tires/wheels.Does it adjust speedometer too with wheel/tire changes in the settings?
