Does v3 charger works on Model X?
Zoomit
2,172
4,055
SoCal
img_9326-jpg.501894
Charging my Raven Model X at a Version 3 supercharger
Rocky_H
5,848
6,684
Boise, ID
I tried both Scotts Valley and Fremont V3 Chargers. I don't get anything above 150 kw. Does it not work with Model X?
OMG. It is working! It is charging your car, and you are getting over 100kW. That is working.
Now what you are probably asking about is why you are not getting the legendary, fabled "250 kW" that the version 3 Superchargers are supposedly able to provide. And the answer is that the Model S or X can never get those speeds. They aren't built internally to handle that. The Model 3 was the first to have that capability, with thicker internal power cabling and a different battery formulation.
Reactions: P85_DA and jboy210
DarkKnight83
64
-10
unnecessary over reaction. We all know it works. We are just griping that a $100000 premium car doesn’t have a feature model 3 has. That’s not good customer service.
Rocky_H
5,848
6,684
Boise, ID
Wow--a newer designed product has better functionality than a much older design. Who could have ever predicted this? This has never happened before in the history of technology. :rolleyes:
If they were both designed at the same time, sure, you could have a legitimate gripe that the more expensive version should have better capabilities.
Janus
215
102
Bay Area
I disagree. With the Raven upgrade, Tesla could have fully back-ported all the battery and charging tech in the M3 to the S/X. Clearly, some things were back-ported, since the Ravens have the 200kW SuperCharging, and one M3 motor. I just don't get what "else" was left out that precluded the 250kW charging.
Reactions: Rocky_H
Soey22
230
139
Fort Erie, ON, Canada
I hit 193kW but wasn’t quick enough to catch it as it quickly started dropping and sat 184 for a good while I’m at 17,300km on my 2019 Raven Performance
Batt Car
Executive, engineer, entrepreneur, author, dad.
Oct 1, 2018
108
62
West Chester PA
How is it that with the internet people can't research things before they ask obvious questions? It is not like this is rocket science (leave that to Space X). Worse yet is that they buy something and then complain after the fact. Ponderous.
jamessssshi
42
36
Vaughan, ON
This is my P100D 2017 build, charging at Niagara Falls V3. However it didn’t last long and most charging above 40% are capped at 100ish kilowatts
mswlogo
5,965
4,572
MA, NH
I could care less and prefer my battery not be put under that much stress. I wish you could choose wattage (within reason).
Soey22
230
139
I would also prefer this, one of the many reasons I avoid supercharging locally, it should be an option when the supercharger is empty and wouldn’t make anyone wait in line. Luckily I’ve been able to find destination chargers to always keep me topped up for daily driving (mostly at work). Since I’m never low I lower the amps to slow charge at 4kW instead of 10kw at home.
Mase408
87
33
Danville
I have hit about 135/137kw on both Emeryville and Scotts Valley v3 superchargers. But i had about 100 miles to begin with. Maybe if I was down to 10/15% battery, I would achieve higher numbers.
