Does your trunk make a loud thump sound before opening?
maximus96
416
258
Bay Area CA
Mine does. The first time I heard it it startled me. It makes the thump sound right when it unlocks, before it starts to open. Not sure if normal and same with others. Thanks
edstewbob
23
7
Piedmont, SC USA
Mine makes a loud thunk sound when closing. Not sure it's normal but not the case in my Outback when the hatch closes. I don't recall if it is especially loud when opening.
Taber
Model Y charged via the sun.
May 19, 2020
30
24
New Mexico
No, it isn't normal. The mobile service tech and I spent an hour in my garage with him loosening the driver side bolts and me pushing on the trunk lid. The issue is that the motorized leg is only on the drivers side of the trunk, and there is a passive gas strut on the passenger side. If you stand behind your car and use your phone to open the trunk, you will see it shift to the passenger side as it opens. What is happening, is the plastic on the trunk lid is hitting the plastic on the passenger side tail light. If you try to adjust the stops, they will screw out until the latch no longer grabs the hatch. I have another service appointment tomorrow, we will see what he can do about it then. BTW, when I removed the rear bumper to put the hitch on, the 2 bolts holding the passenger side tail light on where finger tight, and would have rattled loose if I had not removed the light and noticed.
maximus96
416
258
Bay Area CA
Thanks for this info, I will mention it when I go in for service this thursday.
Reactions: Taber
johnmodely
256
182
NY
Yea I had this issue. Took it to service and they had it for a week to fix it. Not sure what the problem was but it no longer gets stuck and makes a popping noise when opening.
Reactions: Dennisis
Taber
May 19, 2020
30
24
New Mexico
Update: the mobile tech was here yesterday and we looked at it again. He is ordering a new gas strut to see if it is stronger and better resists the lifting force of the motor strut. We will see if this works.
SQLDevDBA
9
Orlando, FL, USA
Someone on reddit mentioned they found that there was a plastic/weatherseal contact issue on the right side close to tail light. The seal would hold, then “snap/thump” and let the trunk open.
I don’t experience the issue so can’t speak to it, just thought I’d throw it in.
