Doesn't regen make AC power? How can my car handle 60 kilowatts of juice?
Discussion in 'Model S: Battery & Charging' started by SuperCoug, Mar 14, 2013.
  1. SuperCoug
    SuperCoug Model S Res #7734
    Bothell, WA
    My 60 kWh Model S is equipped with a single 10,000 watt AC on board charger which (as I understand it) converts AC power from the plug and to DC power to store in the battery.
    The Model S has an AC motor so doesn't it produce AC electricity during regen braking? If so, how can my car possibly handle 60,000 watts of AC power during full regen? If it can handle that much AC power from regen why can't it handle that much shore power?
    I'm sorry if this is a dumb question or has been explicitly address elsewhere.
  2. Stoneymonster
    Stoneymonster Active Member
    Aptos, Ca
    I'm guessing it goes through the main inverter between the motor and the battery somehow. Can inverters be reversible?
  3. strider
    strider Active Member
    NE Oklahoma
    Yes, the same way it takes DC from the batteries and converts it into AC for the motor, just in reverse. In the earliest Roadsters they actually used this to charge the car but it had some problems so they went to a dedicated charging circuit.
  4. FredTMC
    FredTMC Model S VIN #4925
    Orange County CA
    omg, I thought about this exact design issue today! Classic. Yep I bet the inverter is utilized.
  5. Johan
    Johan Funds for M3 secured. Contingent on wife aproval.
    Drammen, Norway
    The Renault Zoe is said to be doing this - using the drive inverter for plugged in charging, which gives it a cheap 43kW 3-phase charger called "Chameleon charger". There have been many disussions as to why Tesla went the route of s separate AC charging system but that's also how most (all) other EV's except the Zoe does it.
  6. Al Sherman
    Al Sherman It's about THIS car.
    Batesville, IN
    So, inverters ARE reversible? I did not know this. We used to call AC to DC a TR (transformer rectifier). If it only did AC to DC would it still be an inverter?
  7. strider
    NE Oklahoma
    A EE boffin/nerd would have to chime in on what it's called. I agree that historically DC->AC is an inverter and AC->DC is a rectifier but Tesla's (and every other EV that I know of) has an "inverter" and it can work in both directions. There's a little bit of detail here:
    Power inverter - Wikipedia, the free encyclopedia
  8. gavine
    gavine Petrol Head turned EV Enthusiast
    Southern New Jersey
    And 2 years later, I though of this question and found this thread via search. Glad I'm not the only geek who though about this.
  9. Kalud
    Kalud Active Member
    Montreal, QC
    The on-board charger(s) are not used in this process. They are 100% idle while driving.
    The inverter is used both ways to re-gen power.
  10. Cosmacelf
    Cosmacelf Well-Known Member
    San Diego
    Does anyone know/remember what the problem was with the roadster combo inverter/charger to charge the car? Why did they switch to a dedicated charger for the Model S?
  11. qwk
    qwk Model S P2681
    Royalty fees to AC Propulsion.
  12. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    When you invert an inverter, do you just get a verter?
  13. NielsHP
    NielsHP Member
    Copenhagen, Denmark
  14. jerry33
    Texas
    No, they're reverberate.
