Dolby Surround to Immersive Sound
brillantesg
45
15
Las Vegas
I'm in a 13 MS and don't have MCU2 but I guess the latest update had just changed my Dolby Surround enhancement to Immersive Sound. Not complaining but will this really change anything? I'm not sure if I can tell the difference between the two .
skitown
869
2,256
Central Idaho, U.S.A, Earth
I have a 2015 85D and notice this setting being toggled automagically from time to time. That said, I find the Dolby setting quite random. Some songs sound much different/better with it off than on; and vice versa. Other songs I don’t here a major difference. But I’m not an audiophile.
Edit: this car has the Premium Sound package.
Ande
740
543
Norway
Good, for Dolby surround to work properly, the track you play should have been encoded for it .
So it's never been a good and useful setting, adding automation sounds like a good thing, dropping the brand name is unimportant.
Reactions: skitown
glide
3,654
3,817
I have the same issue in my 2015. Sometimes Dolby is there and sometimes it switches to Immersive.
None of the Immersive settings actually do anything the impact the sound.
Glad I paid extra for the premium audio...:/
M.V.P.
35
22
Somewhere, USA
Has anyone else noticed that the Immersive Sound setting is not remembered between drives? I'll have it set to HIGH but after leaving the car parked for any significant length of time (e.g. greater than a few hours) the setting reverts to MEDIUM. I have a 2017 MX w/Premium Sound on the latest software version 9.0 and typically switch between using Slacker & TuneIn and sometimes notice the Immersive Sound setting change between those sources as well. I think this is a recently introduced bug when Immersive Sound was rolled out as the previous Dolby settings were always remembered for me. I haven't reported this issue yet myself nor have found anyone else on the forums complaining about it. Thanks.
cruiserlarry
Gadgetologist
Jan 24, 2017
284
350
Los Angeles, CA
My Dolby Sound has changed to Immersive sound and back again several times over the course of several updates. Currently on 2018.48.12, and it's reverted back to Immersive Sound. The issue I find most annoying is I can't hear any difference between any of the 3 levels in Immersive sound, whereas I could immediately hear a difference activating Dolby Sound. I'm guessing that it is because my 2017 S90D MCU1 doesn't have the Immersive sound hardware and can't react to the options until it is returned to Dolby Sound control programming, but that's just my guess.
Anyone else notice that Immersive Sound is unresponsive when used in an UHFS vehicle originally equipped with Dolby Sound?
glide
3,654
3,817
Yes. I posted the same issue above.
cruiserlarry
Gadgetologist
Jan 24, 2017
284
350
Los Angeles, CA
Just noticed my 2017 S90D changed from Dolby sound to Immersive sound this morning WITHOUT any software update involved. This is certainly becoming annoying, since the Dolby Sound already has an issue randomly toggling on and off by itself, and now it switches to a non-functional Immersive Sound mode without any other interaction involved....
Reactions: markn455
markn455
371
144
Ball Ground, GA
I am having this same problem. Immersive sound does nothing on MCU 2.0. You have to have the new MCU which started with late Q1 2018 cars. Mine keeps switching on and off as well.
Pantoot
81
36
Arizona
In my case it seems like every time I notice the switch from Dolby to immersive when I check the web browser I see that it doesn't work either.
Almost like the MCU or whatever is running out of memory or something crashed.
After I reboot both the web browser and Dolby options are are back.
