Dome lights
m3gt2
870
297
england
Hi, can someone tell me what the auto setting does for these as I can't find any logic with it! I thought it would be either on when a door is open or on when a door is open and it's dark but they never seem to come on when it's dark!
rotor2k
476
251
London
Auto for me behaves like traditional interior lights: they come on when the motor is off. So you unlock the car and the lights come on, you get in and put it in drive, they switch off. You arrive at your destination and put it in park, the lights come on.
Reactions: m3gt2
MacJester
84
24
Cranbrook
I had this problem - in the end I found out the dome lights were physically off at delivery. If you turn them on and set to auto it should be ok (tho perhaps worth checking that there isn’t an “always on” state to drain the battery like in an ICE car.
Reactions: m3gt2
m3gt2
870
297
england
Thanks, I was hoping you would be able to get them too work with the doors but I guess you nearly always put it in park when you pull up anyway.
Oldschool496
704
396
Florida
Just seems a very odd way for them to work!
There are things, that depending on your training, the industry you may work in, your previous car and where you were raised, that seems like things don't make sense. This is not one of them for me.
However, there are some things on this Model S that you have to ask yourself: who thought this through? Who is doing the describing here? Not car people, computer people. I'm both of those, so its easier to decipher the minds of "Minolta".
Perhaps in this case if it just said "Normal, with fade to off", instead of "Automatic". Or just "Normal". Its too normal, I think, to do that.
Reactions: m3gt2
Cyborg68
35
12
UK
I seem to be having a problem with mine... when I set it to auto it resets to off after the car is locked/unlocked!
I've rebooted the car and the screen but it doesn't make any difference.
Anyone else experiencing this (its bloody annoying getting in a black car with a black interior in the dark and having no lights) and/or have a solution to make sure the setting is 'sticky'?
Mr H
1,444
1,441
Manchester
I’ve replied to your other post about making sure you are saving to the correct profile as every setting needs to be saved
WannabeOwner
5,758
2,893
Suffolk, UK
If you open the door [without selecting Park] the car will go into Park, so that should bring the Dome lights on too (but I haven't specifically tried that)
Realaustin
40
25
Scotland
Mine were off at delivery so I set them to auto and they’ve been working great but they have turned themselves off a couple of times and I’ve had to keep switching them back to auto.
Reactions: WannabeOwner
m3gt2
870
297
england
Thank, after trying many combinations I realised that the best solution for me was to put it in park every time someone was getting out of the car, this puts the lights on as mentioned but also ensures the doors all lock when you pull away again.
