I know if I expand the screen I can see it. But by default/normally it is not expanded as it covers all controls/screen. Hence the suggestion that they Temp display can use colors to indicate the same without having to go to expanded mode. User can decide if they want to turn it off by going manual.It does show blue/red for cooling and heating on the expanded screen.. the one where you control the air flow. You just can't turn off heating. You could set the temp to LO and turn off AC.. that should do it...for SoCal. But if you are at colder places where temp drops below freezing, I don't think you can ever turn off heater.... not that you would want to.
What does the fan icon on the app do? Doesn't it just ventilate the car?
How is that different from the climate button?It opens up the climate controls panel. Or a long press will turn off the climate altogether.
EDIT: Oh, on the phone app? It turns on the climate system and does whatever it takes to reach your set temperature ASAP.
If you have it on auto the day before in warm afternoon sun it may be cooling you down to 70. The next morning it may be heating your car up to 70.I don't have my car yet so full disclosure (although so far still looking good for Friday morning delivery) but isn't this issue "solved" by not keeping the climate system on Auto? My Infinit QX60 seems to do something similar. If the setting is Auto, then it will move the temp to the set temp, whether that involves pushing cold air into the cabin or hot air.
Here in swampy Northern Virginia, I appreciate the mix of heat and a/c together, as it improves dehumidification. On a couple of recent trips in moderate weather, I've noticed heat on the floor and air conditioning from the dash vents, which felt fantastic. Still, I think a heat-off button would give the driver some additional control over comfort and energy consumption, although that does creates the opportunity for people who aren't familiar with advanced air conditioning system operation to create uncomfortable (or potentially hazardous, if the windows fog up) cabin conditions.I agree with this. I wish there was a heater off button. I noticed the car does mix heater with a/c to get to a comfortable temperature. I sometimes lower the temperature and turn off the a/c to prevent this from happening.
The 3 should do that as well with the temp set to low and the A/C turned off.I loved the "Fan Only" option in my Volt and used it all the time. I wish other EVs would have this, simply for times like this when we dont need heat.
Correct, it does. But with the Volt, you could simply select Fan Only and not have to deal with turning the temperature all the way down.The 3 should do that as well with the temp set to low and the A/C turned off.
I just turn the entire HVAC off.
That is also one option, but if I feel a bit hot inside and would like to cool, but outside air is cooler than set temp, you'll automatically get heat to cool the air inside. This doesn't make sense - use heat and high fan speed to cool inside - instead, it can use outside air with no heat and low fan speed to do the same.I just turn the entire HVAC off.
