Is the alignment problem with the leading edge of the passenger door/mirror trim, or the trailing edge of the front fender. At first glance I thought it would be the door, but on second thought it may be the fender that sticks out too far.Anyone know if there is an easy way to fix that gap...without requiring an SC visit? 2020 (Oct) SR+ of that matters...
How does it compare to the other side?
I had this exact problem on my 2021 m3. Took it to service and they fixed it perfectly. (noticed it on the first day, so they fixed it for free)
Now, the driver's side is different because it is slightly out of alignment.
If I had known it was supposed to match up perfectly and could be fixed, I would have told them to take a look at the driver's side too.
This was done in a few hours. Including, the rear passenger side door handle was about 1/16 inch more recessed than all the other door handles. That was fixed too. They also checked tire pressure and other free safety checks.did they have to keep it long? just asking before I call...
After fix, after 1 month:This was done in a few hours. Including, the rear passenger side door handle was about 1/16 inch more recessed than all the other door handles. That was fixed too. They also checked tire pressure and other free safety checks.
13mm bolt on the hinges.
T45 torx at the striker.
These pics looks like the upper hinges can be loosen and adjusted outward.
The hinge bolts are on the "frame".I’d be trying that on the upper hinges, attached to the door - not the frame?
