Door handle finish bubbling
Discussion in 'Model S: Interior & Exterior' started by Doug_G, Mar 30, 2014.
  1. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Well, this is weird. The finish on my driver's side rear door handle has bubbles in the surface finish.
    When I first got the car, the driver's door handle started corroding prematurely, no doubt due to some kind of coating issue. This is rather different, and suggests that the newer handles have a different kind of finish (my door handles have all been replaced at least twice now).
  2. Bardlebee
    Bardlebee Member
    San Antonio, TX
    Would this actually be covered under service or would you have to buy a new handle?
  3. Jason S
    Jason S Model S Sig Perf (P85)
    Rocklin, CA
    Of course it is covered under warranty.
  4. mknox
    mknox Well-Known Member
    Toronto, ON
    With the weather getting a bit warmer, I actually spent some time wiping down the car after a car wash on Saturday (still too cold to hand wash in the driveway). I haven't noticed anything on the door handles (will look closer), but did notice some tiny rust spots on the chrome strip that runs between the tail lights and the chrome finish is flaking off the "T" logo on the rear trunk lip.
    I've already had the side turn signals replaced for corrosion and was going to start a thread on "trim piece corrosion", but this is as good a place as any to discuss.
  5. Alysashley79
    Alysashley79 Active Member
    Seattle(ish) WA
    the little "T" I'm not entirely surprised about it's just a plastic T painted with some form of chromed material. At least mine is. I actually have a two on my car and then two of them sitting on my desk waiting to be installed on my wall after I finish painting it (after I had the MS xpel'd they gave me all the little trim pieces to keep) now all the actual chrome pieces I would assume are actually chrome.
  6. mknox
    Toronto, ON
    Oddly, the one on the front of the car that takes the worst beating seems okay. It's the rear one that is flaking. You're right... it seems to be plastic with some sort of chrome-like coating.
  7. Alysashley79
    Seattle(ish) WA
    I'd almost disagree that the front one takes all the beating. Yes I know it would seem like it. But every time it rains all that rain and muddy water gets splashed up and back onto the back hatch. I know this. Because I travel down a 3 mile dirt road daily to get home (and yes it's quite well maintained) but because of this I can see where all the water from the road hits as we drive etc. my t in the rear is usually caked in dirt. I know most peoples probably isn't but that being said it's still taking a beating from water and all those chemicals that the DOT outs on the he roads to keep us on the roads during winter. Just my two cents..
  8. Vexar
    Vexar Member
    Citrus Heights, CA
    I will admit I've had two handles replaced due to bubbling of the crome-like wrapper. I was told it was applied through an electrical adhesion process (which I cannot explain), and on a humid day, it doesn't go so well. Water gets in between as a vapor during assembly and blisters out. It is a warranty fix.
  9. Doug_G
    Ottawa, Canada
    Interesting. I think they may have changed the way the handles are made. Back in 2012 my first driver's door handle was defective and started corroding visibly. It looked very different from this.
  10. MoeMistry
    MoeMistry Local Vendor - SoCal
    Southern California
    The door handles are in fact metal and chrome plated. They're actually pretty heavy. Makes for a great paperweight ;) Don't ask me how I know.
  11. darthvdr
    darthvdr Member
    los gatos, ca
    Doug_G, did Tesla replace it?
  12. Doug_G
    Ottawa, Canada
    They offered to send a Ranger on Wednesday but I'm not available that day. So it will have to be fixed later in the month.
  13. capt601
    capt601 Vin02324
    Mission Viejo, California, United States
    Service is only the annual inspection. Which includes wipers, fob battery, inspection, tire rotation. Not much else. This is warranty. Everyone gets parts replaced for warranty, no service plan needed.
